1985 6070 thrust bearing?
rrhead(SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rrhead(SD) Quote  Post ReplyReply Direct Link To This Post Topic: 1985 6070 thrust bearing?
    Posted: 13 Jan 2011 at 3:38pm
Did the late model 6070's have the thrust bearing fixed from the factory? Called about one and owner didn't know anything about it on the tractor. Thanks, rrhead(SD)
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2011 at 5:36pm
sn 33k-21863 was the split where the front kit was not needed - most 6070's all had the wide thrust flange cranks - I always check thrust on 433's  -  At about 5000 hours it is good to drop the pan, check the balancer over, check the shimming  and roll in a new thrust brg.
This page was generated in 0.143 seconds.
