d14 connecting rod position
mjbower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mjbower Quote  Post ReplyReply Direct Link To This Post Topic: d14 connecting rod position
    Posted: 12 Jan 2011 at 9:08pm
do the number one and three conn rod piston pin clamp bolt face the cam and the number two and four face away from the camshaft  does this sound right thanks for the help
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2011 at 9:15pm
I don't remember if it is those #'s but 2 face one way and yhe other 2 face the opposite way, It's do to the offset for the bearings, Bob
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2011 at 9:45pm
Look at the offset on the rod caps. When in doubt watch close as the rod bearing locates on the crankshaft. If it is correct it will be centered on the journal. If it is backwards it will not center and if you attempt to tighten a rod cap it will bind on one side.
The picture will also show you which way they go.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mjbower Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jan 2011 at 11:01am
Thanks again for the info the picture for sure refreshed my memory
1946WP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1946WP Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jan 2011 at 6:51pm
short side of rod cap goes toward the main bng. believe it or not they will run when they are in there awrong. my D14 had 2 in wrong when I bought it . It ran but not very well. It had other back yard overhall problems also.
This page was generated in 0.089 seconds.
