strange 175AC
old220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote old220 Quote  Post ReplyReply Direct Link To This Post Topic: strange 175AC
    Posted: 12 Jan 2011 at 9:41am
Ihave a 175  without 3point, draw bar, and hydralics otherwise a bareback,  is it rare, was told it came from florida, it has1500hrs. runs excellent, were there any more.
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2011 at 9:53am
Interesting, could you post pictures? I suppose it must have had something mounted on it... I don't know how you would use a tractor without a drawbar otherwise. Are there hydraulic outlets on it?
Dean/MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean/MN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2011 at 10:33am
I think he's saying it has drawbar and hydralics but no 3pt or pto.
HD16,917H,185,7050,8030FWA,8050FWA
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2011 at 10:39am
I saw a D14 that had no snap coupler once. I think it had plugs where the lift arm shaft would have gone through the housing. Seems to me there was something else missing too like maybe hydraulics or PTO. Was almost 20 years ago when I worked at Peterson Implement and I didn't pay all that much attention.
Wink
I am a Russian Bot
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2011 at 10:56am
Saw a "base" D-17 at a show I think it belongs to Mayers. Had no Snap Coupler, no hydraulic pump, no tach, and I am pretty sure no PTO or power director. Was odd looking when you looked it over close.
Breeze View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Breeze Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2011 at 10:57am
Reeves/Holland Construction in Dublin Ga has or did for years, a D-17 with no hydraulics, no three point lift and no drawbar.  They had a pintle hitch bolted onto a plate on the rear.  All they ever used it for was pulling a sheep foot packer and a spraying unit with self contained pump set up.
My D-15 didnt have 3 pt or SC, pto or draw bar either. Hydraulics were run off a crank driven pump on the front for the backhoe and loader.
Post Options Post Options   Thanks (0) Thanks(0)   Quote old220 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2011 at 12:34pm
The 175 does not   have anything on the backexcept the pto, no hydralic controls the pumpis onthe front for the power steering. Iwas told it was sprayer tractor in florida andwas one of 14 made,I will tryto get pictures,
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2011 at 3:32pm
Tractor was destined for Canada ; thats the way they wanted them
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2011 at 6:26pm
Does it have a shuttle shift instead of a power director?
dpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dpower Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2011 at 6:29pm
Our 170 shuttle has no three point with a wide draw bar
Bill Deppe/AC Salvag View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Deppe/AC Salvag Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2011 at 8:02pm
Parted out a 170 without three point, seller claimed it used to be a state road mowing tractor. The hyd pump didn't have the section for the three point either.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2011 at 9:47pm
Most "bare back " tractor were for industrial use. Mounted backhoe or other dedicated implement on them. Most had the shuttle shift on them and a front mounted hydraulic pump. Bob
