Do 125ci sleeves fit in a 116ci B motor? |
JR Maley
Topic: Do 125ci sleeves fit in a 116ci B motor?Posted: 11 Jan 2011 at 3:50pm |
Do 125ci sleeves fit in a 116ci B motor? What is needed to go to 125 or larger in a hand crank start B? I would like to keep the compression ration around the same for easy starting.
-JR
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3546 |
Posted: 11 Jan 2011 at 5:04pm |
gee, all b's except the early Wakeshau B's had 125 CI engines 3 3/8" bore 3.5" stroke
right?
RichinWis
Joined: 11 Sep 2009 Location: Deforest Wis Points: 691 |
Posted: 11 Jan 2011 at 5:23pm |
The early ones had a 115 CI engine then the 125
TMiller/NC
Joined: 11 Sep 2009 Location: Lenoir, NC Points: 1776 |
Posted: 11 Jan 2011 at 5:28pm |
The BE engines were 116 cu. in. with 3 1/4" bore. Tim |
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 89248 |
Posted: 11 Jan 2011 at 5:37pm |
the original BE was a 3-1/4 inch bore. Later the same block was fitted with bigger ID sleeves to get 3-3/8 inc bore. Same rods, valves, crank, block... they all have interchangable parts. Most aftermarket kits are now 3-7/16 bore and will go into the BE or the CE block. Compression is probalby 6 or 6.5 to 1 on most kits.
JIminArkansas
Joined: 13 Sep 2009 Location: Malvern, AR Points: 26 |
Posted: 11 Jan 2011 at 7:26pm |
When did the 3-7/16" overbore kit come out for use? I have an old B from a fence row find and it has the larger overbore pistons in it. It was stuck but a little gasoline in each hole and a match and it was free. Took longer to take the head off than to get it unstuck.
Chalmersbob
Joined: 11 Sep 2009 Location: Pennsylvania Points: 2122 |
Posted: 11 Jan 2011 at 9:34pm |
All you need are the sleeves, pistons and "O" rings.
Nothing major to do. Bob
steve(ill)
Posted: 11 Jan 2011 at 10:01pm |
Thats a good question Jim. I always thought it had something to do with Allis going out of buisness and most aftermarket parts being made overseas after that.. I dont have a clue to the answer, but will guess mid 1980s.
TedBuiskerN.IL.
Joined: 11 Sep 2009 Location: Davis, IL. Points: 1959 |
Posted: 11 Jan 2011 at 11:25pm |
I have a 1957 Tractor Supply Blue book that shows the 3 7/16 overbore kit for the B, C, CA, and RC. That was about the time the power race started.
