g parts for sale
Andrew Kimbrough View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew Kimbrough Quote  Post ReplyReply Direct Link To This Post Topic: g parts for sale
    Posted: 11 Jan 2011 at 1:44pm
I am parting out a G and have a good amount of parts for sale.  I have the following:
- Good radiator.  Holds fine, a few minor dents. $120
- Rear axle and axle housings, good bearings, new style cast iron brake hubs included as well  $170 a side
- Rear rims in good shape  $110 a side
-Front rims $85 a side
- Rear centers, have been welded, in good shape.  $20 a side
-Brake shoes in really good shape $30 a side
-Front tie rods $95 for the pair
-Torque Tube $65
-Transmission parts (gears, actual housing) No low gear  $varies
-Excellent throttle with like new teeth $35
-Original steering wheel in good shape $50
-Steering shaft and gear $115
Pictures available on request.
This about sums up what I have, but if you have questions on any other parts let me know and I will make sure I dont have them.  Message me back here or pm me or call 765-730-6056.  All parts located in Daleville, Indiana.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew Kimbrough Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2011 at 8:57pm
bump
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2011 at 9:17pm
Andrew, I'm looking for the rod the goes from the throttle quadrant to the governor.
Do you have one? Thanks
Bob
Joe(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2011 at 10:06pm
Do you have a steering tube, that part that the steering shaft runs in in-between the the steering wheel and the box?
 Thanks,
 Joe
Life is simpler when you plow around the stump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Andrew Kimbrough Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2011 at 7:37am
Bob, I do not have that part.  It went with the engine when I sold it.
Joe,  I believe I do but let me check and make sure and I will get back to you on it.
