WD spin-out wheels
Floodwoodflash View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Floodwoodflash Quote  Post ReplyReply Direct Link To This Post Topic: WD spin-out wheels
    Posted: 11 Jan 2011 at 12:06pm
Greetings all, I've been working on my recently aquired 52 WD, I finally tried to loosen the wheel locks to move the rear wheels out, I got 2 loose and that's it.  Anybody have a suggestions on how to get them loose. Pulling the wheels off is out, loaded tires and lack of space, plus 2 feet of snow. I've been soaking the locks for about 6 months. Sears will replace 1/2 inch broken breaker bars, have 2 new ones now. TIA, Tim.
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2011 at 12:24pm
Unfortunatly, you have been doing everything you can do with out removing the wheel. I guess the next step would be to use some heat on them to remove the rust. Also from the backside you can hit the center pin with a hammer to loosen up the rust. If that don't work then you will have to remove the wheel from the center section and take the cams apart and clean them up.
Jeff(WD45-SATX-TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WD45-SATX-TN) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2011 at 1:53pm
Welcome to the forum Flood!
When I did my WD45 a couple years ago, she was sitting outside for about 10 years, they were stuck good. Lost of PB Blaster and some good hits from the inside of the rim, right on the pin itself. I used a 6 pt impact socket on my 1/2" breaker bar. Then put the handle from my floor jack over that for a 5 ft cheater. Sounded like a shot gun when they finally broke loose. I snapped a shorty impact extension. Then went to a deep 6pt impact socket. By the time I had the first wheel done, the PB had done its work on the second. Those 4 turned pretty easy. Good luck, and be careful. Wear gloves and some eye protection!
1954 WD45 NF "Iron Tater"
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2011 at 3:42pm
Don't use too much of a pipe extension or cheater bar.  I twisted off the head on the eccentrics on my CA.  FWIW.
Brian
Edited by Brian F(IL) - 11 Jan 2011 at 3:44pm
pjs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pjs Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2011 at 4:22pm
why not unbolt the assembly fromthe rim,just 2 bolts,put the assemble in stout bench viceandremove the lock ring at rear, drive pin to and fro using rust penetrant, and a bfh. in the past, trying to get them loose on the tractor i have broken extensions,sockets,breaker bars.rotate wheel to top and do one at a time, make it easy on your self. good luck!
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2011 at 5:57pm
Same here, can't you do them one at a time.   When in the vise the first thing I would give it is a good application of the rose bud.  That is what Mine took, but I had all apart.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2011 at 6:29pm
Take one complete assembly off at a time(2 bolts holding it to the wheel center). Clean and grease with never seize and replace. If you get it turning, your halfway there. After you get it to turn remove the snap-ring and pull the eccentric out to clean and grease inside.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2011 at 8:53pm
The ones on my D14 and D15 were completely seized.  Unbolted them from the wheel centers and removed them from rims.  Right after that, I threw them into (not on!) my air tight wood stove and let them cook for an entire day!  They loosened up real easy after that.
I took everything apart and sandblasted and primed all the pieces, so they should work real smooth now!
I tried the cutting torch earlier, but did not help at all.
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2011 at 10:48pm
Penetrating oil and a 3/4 air gun will do if you must leave them in the tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2011 at 10:54pm
I don't like the cooking in the stove idea.  The shafts are heat treated steel, and I'm afraid you would soften them to much with that much heat for that long a period of time.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2011 at 11:02pm
Jack up the rear end and rotate the wheel to a convenient spot for each and work the eccentrics  back and forth with a couple of hammers, then use a big breaker bar on the socket.  I've done a bunch of them and this has worked the best for me. If they are rusted so bad you can't recognize  the snap rings on the back side, you will probably need to remove the whole wheel and find some better assemblies.
ALLIS EXPRESS!
This year:
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2011 at 7:24am
Tim welcome aboard!! Im about 50 miles north of you. I like Eldons advice and others, Ive done a few and they are a big job. I have a friend in ND that broke his hand getting his loose so be carefull! Mark
Post Options Post Options   Thanks (0) Thanks(0)   Quote Floodwoodflash Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2011 at 8:25pm
Thanks for all the advice guys, I'll try moving them back and forth with a bfh first, if that won't work I'll pull them off one at a time.  I know all about breaking body parts while working on tractors, blew my shoulder out this spring, keep on telling the wife that a $700.00 compressor would have been chaeper than a $1200.00 shoulder job.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Floodwoodflash Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2011 at 8:26pm
  oops, should have read $12,000.00 shoulder job.
This page was generated in 0.083 seconds.
