WD-45D Parts Book/Gasket #'s
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Topic: WD-45D Parts Book/Gasket #'s
    Posted: 10 Jan 2011 at 6:34pm
In making a gasket for the WD-45D 230 diesel engine, the Agco parts book shows 2 different numbers for same item, Timing cover has 2 different numbers, does anyone know if this engine went thru minor design changes to various pieces? The picture in book of gasket I'm making actually shows 1 hole "opposite" of my cover/gasket. I know i can caulk that up to printer error, but double part numbers has me thinking.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2011 at 6:38pm
It might be like the 262 in that there is a metal plate that is the front engine mounts that's sandwiched between the timing cover. Just put a 262 together and that's what they have, 230 might be similar.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2011 at 6:48pm
Looking again in parts book, there is 2 columns for Qty, same item, 2 different numbers, shows 1 each in opposite columns, maybe different numbers when ordering seperate?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2011 at 6:55pm
On the 262, the gaskets are not the same so you need one of each. Is there a good picture? I'll bet that's whats going on. One number to seal the plate to the block and front of the oil pan. The other one to seal the cover to the plate.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2011 at 8:13am
Brian is spot on about the two gaskets one in front of the plate to cover and one behind the plate to block.
Don
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2011 at 6:50pm
  there are 2 different gasket sets listed for the 230  different rear seals  need to know which you  have before ordering
This page was generated in 0.044 seconds.
