D15/D17 front ends
gmoore View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gmoore Quote  Post ReplyReply Direct Link To This Post Topic: D15/D17 front ends
    Posted: 10 Jan 2011 at 4:51pm
 I would like to put a wide front end from an early model D17 on a D15 seriesII that has a narrow front end.  Are these interchageable? Thanks,  Gerald
RichinWis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichinWis Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2011 at 5:40pm
Sortof yes and sort of no, what I mean by that is that some parts do interchange and some don't. The casting that you bolt to the bottom of the bolster should bolt up. there are alot of different part numbers for a D17, through the series. The problem comes in when you go to put the wide front part on itself. I dont think you can bolt the wisbone part on without modification, and the spindles are taller I believe. With that being said, if I couldn't find the right one, it could be done with some work. How do you like that answer. PS one thing about me is I am a machinist, toolmaker so I always say "never say never. HTH
This page was generated in 0.049 seconds.
