D14/Plow Question
Jamie (KY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jamie (KY) Quote  Post ReplyReply Direct Link To This Post Topic: D14/Plow Question
    Posted: 09 Jan 2011 at 10:16pm
I've been thinking of getting a plow to go behind my D14. Well, to be honest, a buddy of mine is thinking of buying one for me so I'll work his food plots in the fall before deer season.
The D14, to my understanding, was designed to pull 3 14's. Is that right?
If so, would that require weight or fluid in the rear tires?
I have no weights or fluid back there but have 90+% rear tread. Would it be better to look for 2 bottoms or 3? I don't want to add weight because most of the time it's just a show tractor with the occasional minor work here and there.
Just when I thought I was finishing my "honey-do-list", she turned the page!!!
Denis in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2011 at 10:43pm
Depends on soil conditions, in my soils a WD45 with loaded tires can handle 2 bottoms but three is to much some times. If I were you I would go with a 2 bottom since you will be able to handle it in all conditions as opposed to some or most, but I don't know what your ground is like I have very heavy ground.
Just my opinion though,
Denis
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2011 at 11:03pm
Used a 3 furrow #73 on mine at a show in the summer.  Also no weights/fluid in miine.  It pulled it, but not very well.  Lots of wheel spin and traction booster kept lifting.  It might work better with more weight over the wheels.  I might load my tires with windshield washer fluid eventually.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2011 at 11:18pm
For gardens or food plots and shows, I would go with 2 bottom. You can take the middle bottom out of a 3 and move the back bottom forward making it into a 2 bottom though. Keep that in mind if you find a decent 3 bottom at a good price.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jamie (KY) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2011 at 3:33am
Thanks guys. This plow buying thing has been in the works for a couple of years now so I don't see it happening anytime soon. I was just rolling it over in my mind thinking about the weight.
DSpears N IL View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSpears N IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2011 at 12:18pm
This is Bob Henry with his D-14 and 82 plow. No fluid in the tires, but 1 set of F & H weights.
DeWayne
Edited by DSpears N IL - 10 Jan 2011 at 9:01pm
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2011 at 12:23pm
I have 2/16 for my D/14 but for  garden spots 2/14would be better. It won,t move soil over as much and chunks will be  smaller plus you get to play with Aiiis a little longer.
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2011 at 12:47pm
make sure you buy an allis snap coupler hitch plow, a trail type one will not work nearly as well. Also, if you go with a 3 bottom, which you should be able to pull as long as it is a snap coupler one, make sure you get one that has the rear lift assist wheel, as they were longer and had a lot more trash clearance. I have one that is the short version, and one that is the longer one, and my D 14 pulls both OK, but I can't go through much of anything trash wise with the shorter one. Just my 2 cents worth, Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2011 at 12:50pm
Both my D-14s easily pull a 3-14 in good soil( no clay).Half bald tires,no fluid either.
Did a couple acres this fall, untouched for 20 years but sandy soil, never missed a beat.Really nice to see the sod rollover...ah summer....won't be long !
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jamie (KY) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2011 at 5:30pm
I have the 3 pt conversion on mine so it would need to be a 3pt plow. The buddy of mine that keeps wanting to do this may end up with a tractor of his own someday so I figure 3 pt would be the most versitle anyway.
From what I can tell, plows are going for about $100 per bottom for something that's not been rebuilt or repainted. I'm hoping to find one at an auction or something for under $100. That would be great. My uncle bough a JD 4 bottom 16 inch plow for $60 a couple of years ago. That just don't happen often.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2011 at 5:42pm
Is your 3 pt a factory stlye that allows you to use your draft control if it is not you may have trouble pulling much of a plow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2011 at 7:09pm
What Denis said!!! If your 3 point isn't connected to the snap couple bell, don't even consider a 3 bottom without fluid or lots of weight. Your traction booster is what made that light of a tractor pull 3-14's. Most 3 point conversions don't allow the traction booster to work.
Jack(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2011 at 7:28pm
I have always pulled 2 with my D14 and it seems about right.JP
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2011 at 5:37pm
I have a snap coupler 2 bottom 14" plow with slat moldboards. It is a model 52 plow. I have  used it on my D-17 to plow gardens,But after installing 3 Pt. hitch on it,I can't use it anymore. It works good for gardens because it is close coupled and you can plow close to fences on the ends. I would consider selling it. I'm in Nicholasville,Ky. If you are interested you can call me. (859) 806-5480 7:30 am -6:30 pm EST
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSpears N IL Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2011 at 7:03pm
Bumping it up for Bob Henry!!!!!
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2011 at 7:10pm
We had a new D14 with 3-14 plow, the first one the dealer got in when they were announced, 1957, rears were loaded, no extra weights.  My advice would be to go with 2-14 or 2-16 if you are not going to add weight.
wheatbreeder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wheatbreeder Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2011 at 7:32pm
My first tractor was D14 with a SC three furrow 14 inch plow loaded tires it worked good in our loam soil. I  sold it and bought an engagement ring for my wife I am happily married  34 years with two both children  married and one granddaughter.  What I'm missing is the D14 and plow to give my grand kids a ride on. The grandkids will have to learn in the 8050
Morley
Farm stuff 8050,6690,175,F2,5050,WD
wheelbilly View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wheelbilly Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2011 at 7:43pm
Put in a lot of time on a D-14 with 3-14 plow back in the 60's.  You need fluid in the rears to handle well.  Was always glad to get on D-17 after a few days with the D-14 but grandaddy always said the 14 would do more than it should based on size and hp.
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jan 2011 at 9:22pm
Jamie, if you have any black clay like I do here you'll be much happier with a 2 bottom of some type. Especially if the conversion hitch doesn't use the draft. I did use the 15 after I fixed it this summer pulling an old ford 2 bottom a lot. worked some old drive way and some hedge row pulling some large roots out. I did spin out a few times on a large root but otherwise in the clay it worked the tractor real well. I had it deeper than it should have been too but I really wanted to push the tractor a little. I don't know for sure but I think it was a 16 bottom. The plow needs it's adjustments freed up to fine tune it for this tractor so it's smoother to operate. Power was no problem, could have used some extra weight on the rears though. Haven't mounted the pie weights yet. Hope this helps, Dave.
