Most Hours on an HD5 or HD6 |
orangeman
Topic: Most Hours on an HD5 or HD6Posted: 09 Jan 2011 at 4:01pm |
Was wondering what the highest hour machine that you know of or have in your collection? Seems most I have seen have around 6 - 8,000 hrs. on them. |
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42268 |
Posted: 09 Jan 2011 at 6:17pm |
I am only guessing but think I have over 11,000 hours on mine . Then in checking the other day when changing filters I noticed last time changed was a few years back and looking in records I have only put 900 hours on it in 6 years.
I bought the machine (HD5G) in 1972 so have had it a few years and is a 1955 srl#
JHanson907
Posted: 10 Jan 2011 at 12:39am |
Do any of you guys have an original (or original type) of hourmeter that still works? My 1950 HD5G has a nice looking one still there, but it doesn't run.
orangeman
Posted: 10 Jan 2011 at 4:17am |
Hello Coke and JHanson907: Coke that is a fair amount of hours, have you had to replace the chain and plates during the time you owned it.
Note to J.Hanson - that is an excellent question, in fact I wonder who the vendor was that supplied the hour meter to AC - might be a Hobbs hourmeter - but not sure.
Coke-in-MN
Posted: 10 Jan 2011 at 8:56am |
I am on my second set of tracks now , second set of sprockets, there were sprocket rings welded on sometime before i bought it . I am on my first engine overhaul yet, put in one new oil pump. Had crank turned as center main was bad, 2nd set of injectors, one head as valve seats burned in last one and it had a non leaking crack but shop said with crack seat would not hold (found out later that was wrong info) 4 new valves.
Replaced master clutch with ceramic button, steering clutches HD11, 3rd set of brake bands, 2nd transmission output bearing,rebuild transmission with new bushing in reverse ideler gear and bearings and 1 tooth on high speed reverse gear, 1 replacement of ring gear bearings and seals, 1 set of top rollers, replaced front ideler bearings and seals.
Update to solonoid type M46 Delco starter, 10SI altenator , 1 water-pump. New cutting edge and reinforced bucket bottom
New brass bushing on master clutch output shaft, REMEMBER, do not idle machine in gear with clutch disengaged, this wears this bushing, put trany in neutral and engage clutch. Edited by Coke-in-MN - 10 Jan 2011 at 8:59am |
JHanson907
Posted: 10 Jan 2011 at 11:15pm |
But does the hour meter still work...??? Just kidding. Sounds like you have had your rig seriously torn apart. I have a leaky seal on the left rear final drive and pretty worn tracks. I have another set on a parts dozer that look really nice, in fact there can't be many hours on them at all. I'm going to delve into breaking the tracks and swapping them out this summer (dead of winter up here in AK right now). Never have done that, so will be a learning experience.
Really would like to get the original hour meter to run. I understand it has a signal from an oil pressure sensor, but haven't chased it down yet. Pretty much just run it every summer, keep clean fuel in it, and change the filters and oil on a regular basis!
Thanks for the advice on idling the rig. Will watch for that.
Coke-in-MN
Posted: 10 Jan 2011 at 11:38pm |
To change the seal you need to drop the truck frame off machine, on a 5B it isn't to hard to do but on the 5G as truck frame is attached to the loader also it becomes a job.
What i did on one machine is make a plate to bolt to truck frame, drill and tap frame and then cut that piece of frame off to allow sprocket to be removed, replaced seals and sprocket , bolted the section back on, welded frame , removed plate and welded rest of frame up solid. Plate held everything in alignment and all worked well.
orangeman
Posted: 12 Jan 2011 at 9:26am |
Coke: Who manufactured the injectors for the HD6, I am thinking they are different than the 5 since the HD5 has the Detroit.
