WC progress
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: WC progress
    Posted: 09 Jan 2011 at 10:20am
This is what I've got done so far. I'm cleaning these intact because they are held solid and easy to get to. I'll clean , wirebrush and blast them better when I get them off the tractor. I've had a couple days off so this is what I been doing.
ToddSin NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ToddSin NY Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2011 at 11:33am
Looking good Thad! Along with the B in the back ground.
Jacob (WI,ND) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jacob (WI,ND) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2011 at 11:41am
Yep, you got most of the hard part done!  Getting the 100 years of gunk off them is the most tedious part in my opinion, LOL!
Keep up the good work, and keep the pics coming!  They give the rest of us inspiration to get ours looking that good.
Jacob Swanson
1920 6-12; 1925,1926 20-35 longfenders; 1925,1926 15-25's; 1927,1929 20-35 shortfenders; C; B's; IB; WC's; WD; WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2011 at 4:41pm
I'm amazed at how much gunk I got off this one. Last weekend I scraped grease and dirt for 2 hrs or so then ran two tanks of gas in the powerwasher over it. When I brought it in the shop so far I've got 3 five gallon buckets packed full of crud off it and still have one frame rail to go.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2011 at 7:42pm
I got a WD45 this last fall from a neighbor.  The frame was solid against the engine bell housing and transmission with dirt.  The hydralic pump was completely invisible.  I didn't know one could get that dirty.
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jan 2011 at 7:47pm
Looks good! Your gonna need alotta grease/wax remover before primer! helps primer stick
