Steps for B, C & CA
mnoonan-NEWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnoonan-NEWI Quote  Post ReplyReply Direct Link To This Post Topic: Steps for B, C & CA
    Posted: 09 Jan 2011 at 10:02am
I have steps available for the B, C & CA. They are prime painted.
PM or email me at mnoonan42@gmail.com for pricing. Thanks for looking.
AC CA, Ferguson TO-20, Ford NAA, M-M BG, AC #3 Mower, SC Plow, PH Digger, AC 720's with Ark 700 loader & Brantly Backhoe, "Mini B" w/flathead Ford V8
caRon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote caRon Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2011 at 11:51am
Hello Mike, that looks really good! I'll email you. I think I just might have to get me one of those. Ron
CA Tractor
JohnThomas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnThomas Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2011 at 12:09pm
Yes, that does look good..simple and uncluttered but functional.
For us older guys tho I'd suggest a small 3/4 inch hi lip up on the inside edge..keep one from slipping off that way...
I like it tho!
Life is short...Make haste to be kind
Murph-NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2011 at 1:33pm
Mine's already on order... looking forward to receiving it.
'41 C w/Woods L503 mower, #3 mower, 2-way plows for C
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnoonan-NEWI Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2011 at 2:51pm
Thanks fella's for the nice comments and John, I like your idea...will have to look into that.
Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnThomas Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2011 at 3:09pm
Thanks..you could just return an up-bend on the flat stock...set the step metal in between.
beeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote beeman Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2011 at 7:40pm
Nice looking and certainly needed item.
1949 B   3930 Ford- Have owned other Orange ,green,red,yellow,dark green tractors and equipment.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2011 at 7:52pm
I got my step from Mike today.  I don't think the photo does it justice... it's much larger and heavier than I expected.  Very well built!  I can't wait to get it painted and mounted.
Brad MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad MI Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2011 at 4:00am
Very nice, well designed. First design I've seen that works on the CA as well as the B & C.
Edited by Brad MI - 14 Jan 2011 at 4:00am
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2011 at 6:28am
would this still clear the belly sickle mower if attached?
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnoonan-NEWI Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2011 at 8:08am
Charlie175,
I don't have access to a underbelly sickle mower, but looking at pictures of one, there is a good chance it would work. You can look at the following dimensions to see what you think.
The bottom of the step is approx. 16-17" from the floor/ground depending on rear tire size and inflation. The inboard edge of the step is about 8" in from the outside face of the fender and the front edge of the step is about 8" in front of the tractor step bar. Regarding finish mowers, I'm not sure about a particular mowers lift height when raised. I would be interested to know what that height is just for my information for future questions of my step clearance also what the frame width is for a underbelly sickle mower.
Thanks,
Mike
Edited by mnoonan-NEWI - 20 Jan 2011 at 3:52pm
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jan 2011 at 7:09pm
You know,  I would have to have a step like this to mount a B, C, or CA.  I remember having trouble as a kid.
Looks like a good job.
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnoonan-NEWI Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2011 at 3:51pm
Thanks again fella's for the nice comments.
Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2011 at 6:01pm
I don't have my mower on now but when I do I will get back to you
Charlie
This page was generated in 0.083 seconds.
