woodlot tractors
Message Reverse Sort Order
Jim Lindemood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Topic: woodlot tractors
    Posted: 09 Jan 2011 at 3:38pm
Brian -- I'm impressed. I'm like the trailer guy and would have bet against it. Those are some pretty good sized logs.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2011 at 10:59am
I have wheel weights, CaCl loaded tires, the rear blade with 4 suitcase weights on it and chains. All of these help when skidding logs. I have skidded oak logs as big as this with no problem.
The front end loader keeps the front end down when I climb some of the steep log roads on my place. I like the back plade on there as it will keep the WD from rearing back on me if a log catches a root.
The bucket comes in handy for moving rocks and such that come up in my way.
I have pushed over many trees up to 10" in dia with the FEL as well. The length with the FEL and the blade make it necessary for me to make a wide path where I need to turn around.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2011 at 10:01am
John...The WD45 will pull more than you think,but just make sure that you have plenty of weight on the front end,so it doesn't rare up on you. We use log hooks/tongs to lift the logs up on one end and skid them that way. We also spin the rear rims out all the way and they have fluid in them for traction. The main thing is to be safe...safety comes first!  Rick
John Ontario View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John Ontario Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2011 at 9:49am
Brian, Those are some nice sized logs. Your wd skidded them out without much problem? I have some oak saw logs that I have been thinking about dropping and pulling out but the price is way down here and they are only getting bigger where they are. I didn't know if my 45 would be able to handle them or not.
John
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2011 at 9:42am
I use my WD. I leave the back blade on and sometimes use it to lift the butt ends a bit to make 'em pull better and keep 'em out of the mud. These are some logs (not firewood) I skidded out of my woods to have sawed. The guy with the trailer didn't think I could load that 14' log for him. It was a Hemlock so no problem; if it had been red oak.....well....maybe not.  LOL
D17 owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17 owner Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2011 at 9:22am
I use my belarus 400. I dont care if I scratch it up I bought it pre dented and cant hurt the value of it it ant worth nothing!
Denis in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2011 at 8:11am
I use a old Cletrac that I bought at a auction just to stop a scrap man from buying it.
heres a picture
It is wore out but works, the previous owner replaced the original engine with a flat head six cylinder from a chrysler.  The only problem with it is the engine turns so fast to build power you cannot push anything but it will pull the world.
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
Tim in arkansas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim in arkansas Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2011 at 8:09am
Back in the day Dad and I would use the WD  then we used a Massy Fergason 50  and we also used my model B for the small stuff  pulled up to the house and cut it up there then used the log spiter
Allis Chalmers fan from Arkansas
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2011 at 7:21am
I'm with you, I use my 45.  Good for pulling smaller stumps too.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2011 at 7:17am
Farmall H off color unit so Ill be less tempted to start fixin and end up with a useless pet.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2011 at 6:53am
My brother and I use D17's and D19's to skid logs with,but have used a WD45 to skid  fire wood logs with (the rest of the tree actually after the log was taken) ,before we started using the bigger tractors. The D17 and the WD45 are pretty easy on gas,but the D19 uses a lot more,but then you've got more horses there and also two extra cylinders. They work real good for us.  Rick
Post Options Post Options   Thanks (0) Thanks(0)   Quote John Ontario Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2011 at 6:35am
I bought a set of chains for my 45 and have been pulling some firewood out of the woodlot the last few days. Great way to spend a day. I was wondering what tractors you guys out there use as a woodlot tractor?
