Dumb Question With Kill Switch
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisChalmers37 Quote  Post ReplyReply Direct Link To This Post Topic: Dumb Question With Kill Switch
    Posted: 09 Jan 2011 at 12:59am
I bought a set of lights and they came with a lighted toggle switch like shown below that I don't need. I had heard a while back that you could use a toggle switch sort of like a kill switch that grounds out the magneto and kills the tractor. Now for the dumb question, is their a way that I could get the light on the toggle switch to come on when the engine is running and turn off when I flip the switch to kill it without doing something crazy?
It looks exactly like the switch above and has the same label on the metal tips as the one below.
Edited by AllisChalmers37 - 09 Jan 2011 at 1:03am
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2011 at 8:02am
I don't think so because you need power to make the light work and you should never have power to it as a ground kill switch.
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2011 at 8:11am
I am not very up to speed on Mags, but the kill switch provides a path to ground for the internals of the mag, if you provide that path even if via a light bulb, it probably won't run.  I don't know what volatge will be on that pin when running, and only when running, even if the kill switch is open (run position) but the tracotr isn't running the light won't be on.  If the tractor has a battery, then I could draw you up a way to do it by adding a relay, but otherwise, I think you are stuck with no light.
Still in use:
Mini190 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mini190 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2011 at 2:01pm
It would not work because it only lights up when the circuit is closed. When the circuit is closed the tractor is off. The switch would work on a diesel tractor because the kill switch kills the power to the fuel pump.
When in doubt, C4
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2011 at 4:32pm
If you have a battery you could use the switch to open a normaly closed relay. It would complacate and ad a failer path to a normaly trouble free simple circut
