WD Distributor
Jim-Tea View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim-Tea Quote  Post ReplyReply Direct Link To This Post Topic: WD Distributor
    Posted: 08 Jan 2011 at 2:32pm
My WD would not start, I found the distributor rotor was not turning. I pulled the distributor and the pin holding the gear was sheared, the grease looked like wheel bearing grease. What should be in there for grease? Thanks for your help.
Jim
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim-Tea Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2011 at 10:42am
bump
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2011 at 11:17am
I put just plane old gun grease on the gears there is a plug on the side of the distributor and the gov housing you can put grease in there. Don't over do it.
This page was generated in 0.162 seconds.
