AC Disc
tom (OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tom (OH) Quote  Post ReplyReply Direct Link To This Post Topic: AC Disc
    Posted: 07 Jan 2011 at 12:25pm
Would one of you guys with the parts books be able to tell me if a 8' AC drag disc and a8' snap couple disc take the same disc blades and bearings?
Thanks
Tom
orangereborn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangereborn Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2011 at 12:46pm
Tom...What are the disc series/#?  There are round and hex gang shafts.  Wood and various sealed bearing styles.  If the "drag" disc is a wheel transport it will have sealed bearings.  Some blades will work on both round and hex shafts if the shaft size is compatible.  The Ball Pac Bearing was used in all the earlier years of sealed bearings but there is a round shaft and hex shaft style.   If you get me the models, I can get you the info.  That would be faster than posting what models had which...Thanks...Dale
