weight and worth wd
D-allis Iowa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-allis Iowa Quote  Post ReplyReply Direct Link To This Post Topic: weight and worth wd
    Posted: 06 Jan 2011 at 7:14am
Iron men around here are really cleaning out groves sheds ect. Iron man called me last nite and said has Allis tractor which i think is a wd on his trailer and do i want it. told him i had to look at it. he said weighs just under 4000#. I hate seeeing any orange go to scrap but at $225. per ton it counts up. I know that$225 is what he gets as he showed me stub a while back unless iron went up. I did get the 7 botton monoframe plow that was going to the crush and will take pictures when i get it in spring.
DOlson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DOlson Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2011 at 7:36am
No way it is that heavy, I moved a parts WD tractor with my 320 JD skidsteer. The  rear tires and wheel centers where off of it.  I picked it up easily, the machine is rated to lift 2200 lbs.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2011 at 7:40am
4,000# shipping weight. That's with hydraulic/rear end/engine oils and unloaded tires. Tires are heavy. I would guess about 3,000#. Just a guess.
Wink
I am a Russian Bot
JohnCinMd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCinMd Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2011 at 8:00am
It doesn't have any weights on it, does it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-allis Iowa Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2011 at 8:11am
am going to look at it soon and not for sure a wd will take camera
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-allis Iowa Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2011 at 9:56am
Here are the pictures. What do you guys think?
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2011 at 10:16am
Not bad for under $450 the rear tires are probably worth at least $300. I'd go for it.
David Gibson (OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Gibson (OH) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2011 at 10:25am
I was gonna say....If nothing else buy it for the tires.
David Gibson
http://www.darkecountysteam.com
1956 WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2011 at 10:55am
You don't want it, I'll take it!!  Go for it!!
OrangePowerGA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangePowerGA Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2011 at 11:30am
Looks good. Buy it....save the orange.
AC - WD
JD - 650
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt (Jordan,MN) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2011 at 11:41am
I don't know about scrap yards in Iowa but around here you can't haul in a tractor, car or truck without prepareing it first. This means that you have to drain out the oils, antifreeze, and any fuel thats in them. You also have to remove the battery and tires. I know on the cars and trucks you have to remove the fuel tank and punch a hole in it so they know that it's drained then you can throw it in or ontop the car so they can see it.  Also what is he getting $225.00  ton for?  Is it #2 prepared heavy iron or dirty cast which a tractor is? Anyway i would take it. The distributor ign. set up is worth $100.00
                  Matt
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-allis Iowa Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2011 at 11:42am
If some one else wants it that would be great including you Ted. . I am going to stop and look at tires again. I didn't get actual price from him but think $450 would be tops. It has combine rims so didn't check tire size but i could sure use a couple good wd rear rims. was hoping for 2 good power shift rims. I like original equip.
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2011 at 12:14pm
   Looks like someone was pretty hard on the throttle side of the quadrant.
http://www.rumelyallis.com
Burnt Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burnt Orange Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2011 at 5:58pm
I work for a salvage yard.The boss just sighned a contract last week for $310 a ton comeing next week and they crush it take it away.With the goverment,Ford GM and retire your ride our yard is full.We cannot sell the motor or any thing to do with emisions.Thats their plan its getting hard for me to find parts for customers 2002 and older unless it chinese aftermarket  junk witch we sell too much of.Also cant drive to work without seeing a one ton flatbed loaded with farm steel.I will not be able to find anything used for My WD.Sorry for the long post I am 59 years old and dont like where we are headed no one will have a job.Brian
beeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote beeman Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2011 at 6:39pm
Same situation down South. There's 3 large scrap processors here in Tuscaloosa and lines of trucks hauling everything you can imagine in every day. If its metal they want it.
 The is a Nucor steel plant here too. And it seems to average 10 to 20  railroad cars of  processed scrap going in and lots of  coils and plate shipped out by rail,trucks and barges.   Somebody ,somewhere  is using all this steel !!
1949 B   3930 Ford- Have owned other Orange ,green,red,yellow,dark green tractors and equipment.
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jan 2011 at 10:51pm
What kind of combine wheels are those that they stick out so far?
Central PA Allis Express
1934 WC254
1945 WF
1945 WC135755
1951 WD68085
1953 WD45-150217
1957 WD45D-230744D
B110
Sandknob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sandknob Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2011 at 8:02am
I'm going to guess 55 John Deere combine rims as my WD45 has the same look to it (although they are rice tires on it).  Looks mean with them on there.
Adam
Reeseholler View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reeseholler Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2011 at 1:44pm
sometimes keeping everything is a good thing. If it was closer I'd offer. It's nice to be able to be offered to take it though before it goes. Be thankful for that
