wd 45 wheel bearing
John Ontario View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John Ontario Quote  Post ReplyReply Direct Link To This Post Topic: wd 45 wheel bearing
    Posted: 04 Jan 2011 at 5:08pm
Need new bearing and seal. Local parts guy can't find it listed. Anyone have the parts numbers?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2011 at 5:17pm
What bearing? If you have the old one, take it to a bearing supply store like Motion Industries and they will match it. Probly cost half what an Agco bearing would.If your talking front inner seal, the old ones were felt. I don't think they are available anymore but there should be a rubber spring loaded seal to replace it.
Edited by CTuckerNWIL - 04 Jan 2011 at 5:19pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote John Ontario Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2011 at 7:03pm
Sorry. Front wheel bearing on a wide front.
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2011 at 7:41pm
There would be 4 different part numbers for the bearings. Inner cup, inner cone, outer cup and outer cone.
http://shops.godaddy.com/GLEMCO-TRACTOR-PARTS/Allis-Chalmers-Front-Wheel-Bearing-Part-No-70228458/?ISC=GGLFD1
Here is a discussion on YT including part numbers.  http://www.ytmag.com/cgi-bin/viewit.cgi?bd=ac&th=108888
Google is a wundermus thing. Just type in "WD45 front wheel bearing", hit the button, and you can find a weeks worth of reading.
Edited by CTuckerNWIL - 04 Jan 2011 at 7:44pm
Chris (swIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris (swIA) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2011 at 9:32pm
Got replacement front seals(felt) for the front of my D17 from Albert at Dean Ag in Maryville this summer. The 45 and early d17 hubs are the same i think.
