WD-45 Question
Zyta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zyta Quote  Post ReplyReply Direct Link To This Post Topic: WD-45 Question
    Posted: 01 Jan 2011 at 9:15pm
There is a small over flow tube from the hydraulic reservoir  that permits the hydraulic oil to drain or overflow into the clutch bell housings. Can this be blocked or plugged off? or does anyone do anything different with this? I really don't want oil to ever get in there and mess up my clutch.
Thanks Jim.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2011 at 9:28pm
Don't over fill your reservoir. It is a breather for your hyd. reservoir.   MACK
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2011 at 11:32pm
further to what Mack said, make sure the hole is not plugged so that it does allow the resevoir to breathe.
Zyta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zyta Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2011 at 10:25am
Thanks!
