G steering wheel, won't come off |
G-Money
Joined: 20 Dec 2010 Location: Street, Md Points: 26 |
Topic: G steering wheel, won't come offPosted: 01 Jan 2011 at 4:15pm |
am I missing something here?......been working on my resto project G and cant seem to get the steering wheel off. Any sugestions? I have the manuals and can't see what the hold-up would be.....just won't come off
JoeM(GA)
Joined: 12 Sep 2009 Location: Cumming,GA Points: 4940 |
Posted: 01 Jan 2011 at 4:28pm |
nothing thee but the nut and the key, rust is an amazing glue! Pull the nut and spray well with your favorite nut buster, let it soak a day or so and try again. You may have to put the nut back on several turns and pull up on the wheel while some one raps the nut to jar it
Allis Express North Georgia
41 WC,48 UC Cane,7-G's, Ford 345C TLB |
G-Money
Posted: 06 Feb 2011 at 2:29pm |
Do I need to stick an awl in the slot as well to jar the key?....good thing I'm getting a new steering wheel because I messed this original up by banging up on the collar
CTuckerNWIL
Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Posted: 06 Feb 2011 at 3:14pm |
Don't stick anything in to punch on the key. You will only swedge it tighter. Do like Joe said, put the nut back on and put it most of the way down on the threads. Lift up or back on the wheel and rap the nut with a hammer. If you only have the nut on a couple threads, you will mess up the threads on the shaft.
Dick L
Joined: 12 Sep 2009 Location: Edon Ohio Points: 5093 |
Posted: 06 Feb 2011 at 3:28pm |
H E A T H O T --- the hub under the nut with the nut about half off. Use a steel block/bar on the bottom edge of the H OT hub and strike hard with a big hammer.
You leave the nut on some so you don't have to chase down the steering wheel. Leave the nut off if you don't mind running after it and bending over to pick it up. At 72 I try to limit the running and bending bit. Real hard to get any thing to seep between a taper lock. Might help on the key way if you have the time. I have never used any thing like that on a steering wheel. Five minute job if you have heat handy.
ibleedorange
Joined: 08 Feb 2010 Location: Harvard, IL Points: 173 |
Posted: 07 Feb 2011 at 1:10pm |
I agree with Dick L. Lots of heat. I tried the soak and wait game for 2 weeks.....didn't work. Tried heat and off it came. Be careful, my steering shaft was hollow and the threads booger-up real easy. Good Luck, Jeff
Tractors; If it runs, use it. Motorcycles: Ride em like today is your last day.
Dave Richards (WV)
Joined: 14 Sep 2009 Location: Fairmont, WV Points: 881 |
Posted: 07 Feb 2011 at 2:07pm |
I put a bearing puller on it, got it good and tight, then hit the tightening screw GOOD with a hammer. Made a hellava noise when it let go. Having the nut on the shaft kept me from wearing the wheel. Hitting the collar of the wheel does the same thing.
Robert Mull Georgia
Joined: 14 Sep 2009 Location: Woodstock, Ga. Points: 211 |
Posted: 07 Feb 2011 at 4:30pm |
I took a portband electric hacksaw and split the center hub on the steering wheel of my D-15 to get it off. Was easy.
Little Allis
Posted: 07 Feb 2011 at 4:52pm |
When we have this problem of removing the steering wheel on our "G's" we used a torch and heated the outside area, then tapped it on the backside with a hammer it usually gave up.
G-Money
Posted: 20 Mar 2011 at 9:03pm |
just to let y'all know how I got that dang wheel off. I let it sit for weeks soaking in solvent and the only thing that got it off was heat....serious heat.....
