Ca hyd pump Help
Pipe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pipe Quote  Post ReplyReply Direct Link To This Post Topic: Ca hyd pump Help
    Posted: 31 Dec 2010 at 4:21pm
 Need a little help, Looking for things to try before I tear my hyd pump apart. pto is on and the traction booster is unhooked and it does not what to pump . please tell me your best trick that worked for you .
Thank you
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2010 at 4:35pm
Take the four bolts out of the Back and remove the control linkage.  If all is well inside its time to remove the pump. make sure you have a clean place to work when you tear it apart. it's fairly easy to disasemble. look for broken springs. clean it out real well. it dosen't take much of a piece to keep the position hold valve from operating. I got new springs from a AGCO dealer.
