DISC WEIGHTS
SIMPLICITY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SIMPLICITY Quote  Post ReplyReply Direct Link To This Post Topic: DISC WEIGHTS
    Posted: 31 Dec 2010 at 2:08pm
 HELLO
    CAN ANYONE TELL ME IF THERE IS A WEB SIGHT WHERE I CAN FIND THE WEIGHTS OF DISC'S ?   THANKS AND HAPPY NEW YEAR'S
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2010 at 2:16pm
What model and size do you have I have some lit on some of them that lists the weights.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SIMPLICITY Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2010 at 2:28pm
THANKS
    I AM LOOKING AT DIFFERENT DISC , AC 2500 CENTER FOLD, JOHN DEERE'S , CASE/IH I WAS LOOKING FOR A WEB SIGHT LIKE TRACTOR DATA
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2010 at 2:37pm
I can help you with the 2500....
width      blade spacing    #of blades    weight     lbs per blade
15'                9"                   40          4265lbs         107
17'10"           9"                   48          4640lbs          97
20'8"             9"                   56          5370lbs          96
I have a 2500 double fold 26' that is a great disk. It does a great job, and levels real well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SIMPLICITY Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2010 at 2:50pm
DANS 7080
  WHAT ARE YOU PULLING THAT 2500 WITH?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2010 at 2:59pm
I have a 7060 and 7080. There both running 210hp. They handle it well. I could probably use my 7040 if I had to but Id have to drop a gear or two.
