off color distributor question
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Topic: off color distributor question
    Posted: 30 Dec 2010 at 3:17pm
Do these numbers make any sense to anyone as to what I have found??
1111558
OG25
I am guessing the first one as a S#, but not sure.  These numbers came off the delco tag on the unit.
It is JD green
2cyl version
'40 WC puller,'50 WD puller,'50 M puller '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2010 at 3:28pm
I thought all distributors were BLACK..lol...
Actually I googled 'delco 1111558' and got several hits, so maybe do the same, and find the info you want?
HOW googled finds this stuff is amazing !
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 30 Dec 2010 at 3:44pm
That's the right length for a Delco part number.
The first hit with Alta Vista (I'm mad at google for not going to the link half the time) says: "Description of PERTRONIX 1121P12: For Tractor Models A, G, and 50, 60, 70 with Delco 1111558 distributor" which hints that distributor was used for at least some of all those models. I'm sure looking up details on a 2 cylinder page would find more.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Dec 2010 at 8:26am
thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2011 at 2:22pm
I'm coming into this a bit late, but the 1111558 is a good Delco Remy number which was used in the JD Tractors. JD: A,G,M, 40,50,60 & 70 Series. And it is for the 2 cylinder engines... HTH
Steve@B&B
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2011 at 2:29pm
Larry If I remember correctly the two cylinder johns fired both cylinders at the same time and in order to time and maybe even adjust the carb  you pulled the wire on the number two cylinder . This will kill a petronix hall effect sensor. I hope my memory has that right.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2011 at 5:13pm
They fired every revolution because I think that made the magneto run twice as fast for better spark. The off time firing was at the transition from exhaust to intake stroke so there wasn't much to burn. The 4.6 L Ford Triton V-8 does that to share coils and ignite any unburned fuel in the exhaust manifold.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2011 at 6:09pm
thanks.  I had the old B sold BUT , the mag decided to die and the guy didn't want it since it was not running.  This came in a box of parts I aquired, but I wasn't sure it would fir where the mag is.  I know nothing about a mag, and a little more on a distributor.  The thing ran the day before, then nothing.  Just a small faint spark.  the left bank will not fire at all and the right one is was doing all the work.  Like Eldon said, keep a green one around to sell if you have to sell something!!
This page was generated in 0.234 seconds.
