NEED HELP MOVING 7060
SIMPLICITY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SIMPLICITY Quote  Post ReplyReply Direct Link To This Post Topic: NEED HELP MOVING 7060
    Posted: 29 Dec 2010 at 7:39pm
HELLO
  I AM TRYING TO MOVE A 7060 WITH A T-SHIFT HANDLE ON THE CONSOLE. IT HAS BEEN PARKED FOR AT LEAST 10 YEARS, I TOLD THE GUY MOVING (OR TRYING TO MOVE IT) TO MAKE SURE THE T-HANDLE WAS IN THE NEUTRAL POSITION, AND THE RANGE SHIFT LEVER WAS IN THE NEUTRAL POSITION.
      WOULD THERE BE ANYTHING ELSE LOCKING IT UP?
                                               ANY HELP WOULD BE GREAT
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2010 at 9:47pm
As long as its not in park it should move even if the T handle and range are in a gear since it uses a wet clutch. I would pull the floor up and see if the range cable is pulling it out of park. If its in neutral and still wont move then there may be big problems.
