Allis Forklift
BrianC,Ont View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Topic: Allis Forklift
    Posted: 29 Dec 2010 at 9:31am
What 6 cyl engines did Allis put in their forklifts. The model# of the unit is ACP80L2PS, Serial#, DBF01464. Would they be a 262. Also he has a smaller unit, with no model# that he said looks like the same engine.
Brian
35WC on steel, B with belly mower, D17 puller, D15 Series II puller, D15 Series II with loader, 608 Lawn Tractor
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2010 at 12:07pm
That would be a 262 Brian.  Happy New year!
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC,Ont Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2010 at 1:05pm
Happy New Year to you Calvin, and all the rest of the forum members. What source do you have for serial #s for forklifts. I done a google search and couldnt find anything. What would you offer for the motor if it was a 262, and hasnt been replaced. Also will it bolt into a tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2010 at 5:07pm
Brian, Check with Kalmar because they took over that line. In Ontario check with Lifttow.
They are still very much in business and were the A-C Industrial forklift dealer. From some brochures that I have, ACP (P=pneumatic) 80 (8000 lbs capacity) L likely means propane 2 likely means two stage mast PS (power shift). The literature is 1982 and does not mention engines. Nothing on serial numbers.  Models starting AC seem to be newer. IS is white and grey with an orange stripe?  Older forktrucks seem to start with FT or FB
I've seen some 6000 lb trucks with the 6 cylinder BUDA.
towmotor tim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote towmotor tim Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jan 2011 at 1:39pm
I have a serial number list. Can you recheck? Open the side door and read off the frame on the right side. D= built in Lexington, SC. B= February.  Third letter is the year. Here is where the confusion starts. There is no F for the year. E is 1978 and H is '79.
Chassis serial numbers are clearer.
