D17 pushrod dilema
sks72107 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sks72107 Quote  Post ReplyReply Direct Link To This Post Topic: D17 pushrod dilema
    Posted: 29 Dec 2010 at 7:33am
Well, still in the process of rebuilding my 226. I need to replace some of or all of the pushrods.  I bought some that came out of a d17 engine and they are different than the ones i have.  The rocker arm end is the same but the lifter end is different.  It seems that if i go with the different style i got i will need to change the lifters also to accomodate the different size pushrod.  I will try to attach a pic(my first time) of what im looking at.  The 2 on the left are what came out of my engine, one being worn and bent, the other being in good condition.  The one on the right is what i bought.  Thoughts and opinions please?? Thanks in advance.
Shannon
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 29 Dec 2010 at 2:09pm
the 201 engines had solid pushrods they should be the same length and diameter as the hollow 226 pushrods with pressed end caps.  unless your building a puller and wanting light valve train components the 201 pushrods are probably more durable . It appears you have two pics. of the same style hollow pressed end cap one has been ran with alot of lash and has spun in the lifter wearing it down on the end over a period of time.
Edited by mlpankey - 29 Dec 2010 at 2:15pm
This page was generated in 0.041 seconds.
