sold the Allcrop 90
HaroldOmaha View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HaroldOmaha Quote  Post ReplyReply Direct Link To This Post Topic: sold the Allcrop 90
    Posted: 28 Dec 2010 at 8:41pm
    Sold the Allcrop  90, went from Omaha, Ne to north central Missouri 266 miles. Built some boxes to raise it up to get it on the trailer. That didn't work as planned. Ended up lifting each wheel a little at a time so the axles could set on two 4x6 beams to clear the fenders, and then used a come a long to pull it onto the trailer. Didn't think the skid loader would pick it up, but it did. And the come a long worked okay to. Combine weighs right at 4,000 lbs.
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2010 at 8:52pm
Sorry you sold it before I could see it!
Greg Kroeker
Jack(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2010 at 8:56pm
When I was little my Dad loaded one on a 2 ton truck by taking an extra truck and backing both up to a loading ramp. They backed the combine on to both trucks and then jacked the side on the right side up and drove the extra truck away. Drove about 250 miles with axle sticking out on the right side (mailboxes are cheaper than Caddilacs). By the way it was not an AC.
