off color but What the???? |
Post Reply ![]() |
AC WD45 ![]() Orange Level ![]() ![]() Joined: 28 Sep 2009 Location: Mid Michigan Points: 2060 |
![]() ![]() ![]() ![]() ![]() Posted: 28 Dec 2010 at 5:25pm |
German Shepherd dad
1957 Allis Chalmers WD45 #WD234847 1951 Allis Chalmers WD #WD88193 |
they claim it runs and steers with the breaks to a degree.
German Shepherd dad
Chris(WA) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Renton, WA Points: 228 |
The great Push-me-pull-you! Looks like two worlds collided! What will someone think of next? Joined at the rear axle facing different directions?
Washingtonian by choice, Wisconsin Farmboy by the grace of God!
Lonn ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29792 |
Siamese Deere. Better put it out of it's misery.
Wink I am a Russian Bot |
split51 ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Guthrie, OK Points: 713 |
I am not much of a Deere fan but it looks like a waste of two decent tractors to me.
1929 20-35 sn17662
B1 w/snow blade B10 w/sickle mower B110 w/mower deck B110 w/tiller B112 w/grader blade B210 w/plo |
Chris (swIA) ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Prescott, IA Points: 319 |
It looks like they finally figured out that 4 cylinders is better than 2. They might finally have enough power to get some work done.
Jacob (WI,ND) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Kenmare, ND Points: 1248 |
articulate it in the middle and you might just have something...
Jacob Swanson
1920 6-12; 1925,1926 20-35 longfenders; 1925,1926 15-25's; 1927,1929 20-35 shortfenders; C; B's; IB; WC's; WD; WD45 |
SHAMELESS ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: EAST NE Points: 29486 |
they never did know if they were coming or going!!
Pa.Pete ![]() Orange Level ![]() ![]() Joined: 01 Oct 2010 Points: 239 |
Gerald J. ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Hamilton Co, IA Points: 5636 |
I think its photoshopped. The tires are in opposite directions so one will pull better than the other. Then if the transmissions are normal, reverse in one might come close to 1st gear in the other, but there's no way to match up the gears. There's not the possibility of flipping the differential ring gear to the other side, there's no right angle drive in the JD of that design.
Then the two radiators that close won't get good air either. Gerald J. |
Dave in il ![]() Orange Level ![]() ![]() Joined: 22 Sep 2009 Location: Manville Il Points: 1748 |
I'd guess photoshop. It would take a lot of time and money for something so pointless and I... Hey wait a minute that sounds a lot like... OH nevermind, as I think about it, it's probably not photoshopped after all. LOL!
Edited by Dave in il - 28 Dec 2010 at 11:51pm |
Reeseholler ![]() Orange Level ![]() ![]() Joined: 28 Mar 2010 Location: Port Matilda PA Points: 294 |
I guess it could be done....but it wouldn't be worth anything really. if you can't turn you can't take it to shows. At our show, a local john deere whiz and an allis guy put a deere and allis together. One was John Chalmers and the other was Allis Deere. Not sure if I've seen them there the last couple of years though. If they're there this year I'll take a picture.
Allis Fields ![]() Orange Level ![]() Joined: 17 Sep 2009 Location: Reedsburg,Wisc. Points: 332 |
Wow a bonus buck... I shoot the one the DNR will give me a tag for the other one, Since there antlers are locked up so tight.
Acualy someone around here did that this year. taged a buck with a bow licence draging a dead horn locked buck. Too bad he used a GUN to shoot it ON THE ROAD. And then braged about it. the Dnr came out looked at them and fined him.
john(MI) ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: SE MI Points: 9262 |
Paddle faster . . . . :)
Pat the Plumber CIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Springfield,Il Points: 4923 |
On RFD they had a show where a John Deere and a Farmall were split in half and joined.They called it "Half Right".When they were done they still had the other 2 halfs so they joined them and call that one "Half Wrong".Basically a waste of 2 tractors ,but they were not A/C so who cares.
1964 D-17 SIV 3 Pt.WF,1964 D-15 Ser II 3pt.WF ,1960 D-17 SI NF,1956 WD 45 WF. |
Coke-in-MN ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Afton MN Points: 41957 |
One muffler, one air cleaner, and steering rod is straight across, no hookup to it for anything. Frame rail straight across, no articulation joint. Unsure of right side machine is a runner as looks like not set up with working engine.
Faith isn't a jump in the dark. It is a walk in the light. Faith is not guessing; it is knowing something.
"Challenges are what make life interesting; overcoming them is what makes life meaningful." |
Stan IL&TN ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |
It's just yard art. Non-functional yard art.
1957 WD45 dad's first AC
1968 one-seventy 1956 F40 Ferguson |
jminpa ![]() Silver Level ![]() Joined: 11 Sep 2009 Location: SouthEastern PA Points: 155 |
There is an air cleaner and a muffler on each of them you can just make them out in the picture as they are straight across from the other
Post Reply ![]() |
