Battery disconnect
Murph-NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Topic: Battery disconnect
    Posted: 27 Dec 2010 at 5:55pm
I'm looking for a battery disconnect of some sort for my C and CA.  I like this style, Style1, but I prefer the price of this style, Style2.  Anyone have others they like, or other suppliers you'd recommend?  Thanks in advance.
Max(ia) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Max(ia) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2010 at 6:40pm
I use the second one of Style1 on my D15II.   Been there for at least 5yrs, works good.  I do however take it off one or two times during the summer and clean it up.
Joe/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe/NC Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2010 at 6:42pm
I put this style on my D-10 Series 1. It is on the ground cable. Easy to get to and you can remove the key for some security.
Joe
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2010 at 7:01pm
Thanks guys.  Joe, I saw that style too.  Do you remove the key to disconnect the battery, or can you just turn it?  I was just concerned I would lose the key... I guess I could put it on a string or chain.
mooboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mooboy Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2010 at 7:33pm
Murph-NC,
I bought some of those with the key on Ebay.  I have not installed them yet.  On the ones I bought, you insert the key, push and turn to connect (continuity across the terminals).  The key is captured in the switch in this position.  When you turn the key back to disconnect position the key is ejected.  You then put they key in a safe place for next use.  The switches I bought came with two keys.  I bought them as a "battery saver" for tractors and trucks that don;t get used often.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2010 at 7:46pm
Thanks Mooboy.
So does using one of these on the ground cable prevent the fires I've heard you guys describe that can happen with these old tractors?  Or does it need to be on the positive side to serve that purpose?
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2010 at 7:54pm
Workes on either side of the battery the same.
Gerald J.
TomSEOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomSEOH Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2010 at 7:59pm
Had one go bad on my Zetor a while back. Took a while to diagnois as the first time or two i thought maybe i had left lights or key on. I took cables off  and bolted together using rubber tape and heat shrink. Don't think i'll replace it , just something else to go bad .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Murph-NC Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2010 at 8:09pm
Thanks Gerald.  Tom, which style did you have go bad?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomSEOH Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2010 at 8:26pm
It was OEM on tractor, no key , just a T handle that turned, bus bar (conducter) burned up at connection.
Brad MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad MI Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2010 at 9:09pm
I've installed them on tractors, RV's and motor homes. They do the good job but can be a maintainance nightmare and fail frequently. Either install the best H D Marine grade unit, or save yourself some frustration and forget it. I just make the ground strap easy to disconnect.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2010 at 9:32pm
Murph, we use one similar to what Joe has on our fire apparatus. I will try to get you a picture of it. It disconnects the ground cable from the frame. We have never had any problems out of these. A couple of then have been in service for 20+ years. For separate dual batteries we use a 4 position rotary switch.
Edited by Hubert (Ga)engine7 - 27 Dec 2010 at 9:45pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2010 at 9:44pm
 Try this website:  http://www.colehersee.com/pdf/hot_feed/D-618_MasterDisconnect.pdf
Look at their 2484 series on page 2. You probably don't need one this heavy duty; a 20 amp continuous rating should be adequate for your application. Most auto parts dealers should have one in stock.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2010 at 8:00am
We carry the ones shown, also have others. Drop me an e-mail and I can send you a pic of what we have. Once installed, a dab of Dielectric grease around the connections keeps the corrosion out. Also offer a Marine style...
Steve@B&B
Bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bee Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2010 at 8:28am
Bob, North Carolina
1949 B
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2010 at 8:52am
some of them can add a lot of resistance just remember to check if you start having starting trouble like others said.
