Gas guage restoration
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Topic: Gas guage restoration
    Posted: 27 Dec 2010 at 9:18am
Is there anyone out there that restores the D series gas gauges? Mine needs a new face, and the magnet evidently went bad.  I know reproductions are available, but sometimes the old equipment is better than the new stuff.  Dave.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2010 at 10:19am
I go hunting through tractor junk yards for mine.  I've been pretty lucky so far.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2010 at 11:59am
I have D-14 guage available. Pretty good shape, may need a new cork? This is the type on tank, must be different than what your after based on your discription
KenBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2010 at 1:30pm
What size/weight cork is required? Are all D series the same?
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2010 at 2:01pm
What I need is for a D-17. The rod on the 14 may be shorter.
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2010 at 2:01pm
I got a float from antique car place for Model A Ford,about $3.50 each.
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2010 at 2:02pm
I don't think weight of cork is an issue since the cork floats. It would just have to be heavy enough to float the rod.
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2010 at 2:03pm
The cork is not the issue on mine, the face is not readable and the magnet must need to be remagnetized.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2010 at 2:33pm
Where does a magnet work inside these guages? Under quick inspection it appears  [ on my D-14 guage] that the rod lifts by cork up/down, turns sprocketed joint and needle revolves, is there a magnet underneath pointer that comes into play? Just inquiring alway's willing to learn
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2010 at 7:01pm
It has a U shaped magnet on the rod that turns on the fuel side. The magnet is able to move the pointer through the metal.
CORY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CORY Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2010 at 11:01am
Where do you find the reproductions?
Kip[NY] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip[NY] Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2010 at 8:28pm
If the info helps, I recently replaced the float (and gas gauge gasket) on our D-14.  I purchased, as Bob pointed out, a Model A gauge float which you can see in the photo with the whole assembly sitting on the hood.  Got the float from Snyder's in New Springfield, Ohio but they're available from many sources.  Ford Part No. A-9313-C.  And yes, only a few dollars.  With the new float, the gauge is working like a champ.
1959 D-14 SN/21089 "Martha"
This page was generated in 0.104 seconds.
