AC 260 scraper
MattR View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattR Quote  Post ReplyReply Direct Link To This Post Topic: AC 260 scraper
    Posted: 25 Dec 2010 at 11:33am
Hi. Just registered. I have a real nice 260 scraper that has been good to us.  I am looking for parts or good replacement transmission for it. It has a 5 speed manual with an air-upshift button. I have found a million 4 speeds and power shifts but need the % speed. Can Anyone help? The S/N is s260-4378.
Thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2010 at 10:43pm
You might find that it is a truck transmission that AC used . Check numbers against Clark or Fuller or such as a lot of the parts came from outside sources. Friend has a 260 scrapper and know on clutch as well as his trany he found things through truck outfit.
 Some of the old parts guys in old dealer network had interchange catalogs. know Sweeney Bros  did for wheile when they carried AC.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattR Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2010 at 7:30am
Thank you for the info.  Any particular truck supplier would be woth the check into? I hope not to have to scrap this nice unit.
Jack(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2010 at 12:44pm
If it has a truck trans in it then there should be a tag on it with numbers. I know a lot logging equipment has truck trans in them.JP
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattR Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2010 at 1:21pm
Thanks for the input. There is a tag with serial #'s which I have given to several large salvage yards to no avail. I know it seems crazy. It was a common machine, I just have an odd tranny I guess. Lots of 4speeds out there and power shifts but not this 5 speed. I truly appreciate people helping me. Whoever gets me a tranny also gets a pizza from me in there home town.
Thanks again
Dnoym N. S. Can. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dnoym N. S. Can. Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2010 at 4:35pm
MattR you can check with these guy`s
TRANSMISSIONS
could be any of these
Borg Warner, Clark, Clark-Hurth, Spicer, Funk
HTH
here at the bottom you can down load
some stuff don`t know if it will be of
any help
http://www.tractorparts.com/interchanges.htm
here you can try for new parts
http://www.minnpar.com/constructionequipmentparts.asp
you may know of these all readed
B:-)    Dnoym
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2010 at 7:45pm
Matt, send me all the numbers and info you have and I will do some  searching. I work in an industrial parts store and we look for odd/hard to find parts every day. I have a lot of sources. Maybe I can help. I happen to like pizza.JP
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2010 at 8:40pm
Another good source of information bmight be Thill Track and Tractor , Eau Clare WI, they have a web site and they have been a source of parts for me on other machines.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattR Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2010 at 6:47am
Hi there. The machine serial #s are s260-4378.  The trans #s are 182122 & 2411044. Which is a model and which is serial I don't know. The tag was kind of boogered up.
My parts book showed the parts we need are:
 Front bearing cover # 182166
Seal #182165
Oil pressure rings # 182052 2each
Bearing #182155
There were also some thrust washers that the book did not show, so I have no # for them. I believe we still have them somewhere so we will reuse them.
I would truly be interested in a good used tranny complete rather than monkeying with this one because it has now become so piece meal.
Thanks again for the help
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattR Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2010 at 6:48am
Oh yea, I appreciate the Thill info. I have used them for 15yrs for all our Caterpillars. They were the first I called. Doug said I'm screwed.
Thanks
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2010 at 9:04am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2010 at 9:45am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dnoym N. S. Can. Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2010 at 7:46pm
http://www.tpaktopc.net/cgi-bin/Clark_Warner
.cgi?findPartNum=+182122
did you try the interchange on this site
don`t know if it will help
B:-)  Dnoym
Clark - Warner Gear Interchange / Cross Reference
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattR Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2011 at 11:00am
Thanks to everyone for the trans info. with this scraper. Will look into it all and see who gets the pizza. May have now found one locally but hope if someone finds one please let me know.
Thanks again
This page was generated in 0.219 seconds.
