D17 D19 diesel piston??
TerryMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TerryMN Quote  Post ReplyReply Direct Link To This Post Topic: D17 D19 diesel piston??
    Posted: 24 Dec 2010 at 9:50pm
Does any body know why there  is a different part number for the D-19 piston vs the D-17/D-15 diesel piston. I bought 4 NOS sleeve and piston kits off ebay a few years ago for a D-15 diesel I am working on. One say D17 the other 3 say D19. The parts numbers match from Agco parts book. So I have one D17 sleeve and piston kit which will work in a D15 diesel. And Three D19 sleeve and piston kits. All of the rings measure the same. The sleeves measure the same. The pistons measrue the same. I think the D15/17/19 use the same sleeve. But the ring kit and piston numbers seem to be different. Looking for any thoughts.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 24 Dec 2010 at 10:18pm
D19 had a lower compression engine, check the piston pin height
Big Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Orange Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2010 at 3:52am
 The early D19 was lower comp. & the pistons have valve fly cuts to clear the intake valve,as they had a different camshaft. The later D19s used the same piston as D17s, but some early D17 & D15 pistons had slightly lower decked pistons.
