How to fix fuel tank on AC 8030?
allisman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisman Quote  Post ReplyReply Direct Link To This Post Topic: How to fix fuel tank on AC 8030?
    Posted: 22 Dec 2010 at 5:30pm
I got a small whole punched in my plastic fuel tank on my AC 8030 and i'm wondering what product to use to fix it.  Thanks for any help I receive.
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2010 at 5:49pm
 Look for a replacement for a tractor you rely on. If your not in a hurry , and have lotsa time , depending on the type of plastic , you might fix it,  Wheres Glockhead? He may be able to explain, better all the types and how to identify exactly what plastic you have and the methods and materials for your specific  task.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2010 at 5:59pm
Drill it big enough for a machine screw and make a couple rubber washers for each side. Put a metal washer and a rubber washer on each side and tighten the nut up. I suppose the hole is some place you can't reach in the inside.
Toscani SD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Toscani SD Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2010 at 7:29pm
take it to a good body shop,they should have a 2 part urethane that should fix it,we did one this fall on a john deere and its still holding,we have norton brand and pliogrip,both good products
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2010 at 7:35pm
Sheet metal screw(as suggested) has worked for me in the past. If it doesn't work your not out of anything.
Leon B MO
