Pushing snow!!
Don Smith View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don Smith Quote  Post ReplyReply Direct Link To This Post Topic: Pushing snow!!
    Posted: 22 Dec 2010 at 12:47pm
Hi Boys and Girls of the orange following, Have you had a chance to push some snow around? It is about the most fun you can have with your Carhharts on. MERRY CHRISTMAS TO ALL!!!!
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2010 at 3:13pm
I pushed a little ice and snow and had to get down to shirt sleeves. That 7010 heater works wonderfull...
"Burgie"
roughstock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote roughstock Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2010 at 3:19pm
We still ain't got nothing worth pushing. :(
Brian
Goose View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Goose Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2010 at 3:35pm
I wish I would have taken a few pictures. On Dec. 11 we had such a snow storm - the snow was more than halfway up our overhead garage doors. I was out plowing with my WD and a snow drift was higher than me on the tractor!
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2010 at 4:16pm
guess we sposed to git sum i think thurs & fri. woopee! i don't have the gnuse on the 7010 yet!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2010 at 4:37pm
Pushed snow 3 times so far all before "winter" got here too. Like ta froze to death the last couple weeks of "fall" and now that winter is here it got up to 40 for a minute or 2 yesterday. The snow is pushed back far enough to have room for what we are supposed to get Thursday afternoon through Friday. I wore my huntin Orange cause there's very little Orange on the tractor and I had to do some clean up out by the road. I would just as soon the crazy drivers could see me from a ways off.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2010 at 7:08pm
Lookin' good there, Charlie!
I've been using the D17 and back-blade to knock out a path from the back barn up to the house, and out to the road... once the worst of it is punched through, I get the little loader-mutt (a mix of Cub Cadet parts with a Johnson Workhorse loader) out to clean it all up nice.  D17 needs chains though...
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2010 at 8:23pm
Merry Christmas to all. Charlie did you buy the blade with the loader or did you put it on the loader? Does it work better than a bucket?
Pastor Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2010 at 8:39pm
Pastor Mike, I made the blade from a 82 gallon electric water heater. I think the Quad Cities Nuclear plant has cut back on producing electric power since I put a gas heater in.LOL Do you have some kind of diverter valve on you tractor to run the loader separate of the blade?
 I think a blade up front is better than a bucket. I have a 5 ft. snow bucket but if you load it up and raise it the back used to get light. I mostly would trip the bucket and use it like a front blade but you can't pile the snow up that way. With the blade on the front, I can bust through 4 or 5 foot high drifts if I want and you're not driving on most of the snow. Now that I have the SC blade and 1 extension I can widen my dozed out path and do a good job of clean up. The front blade is tipped back and riding on the angle Iron support and mounting bracket or it will dig 12-18 deep in the yard before you know it. It doesn't clean well that way but that's what I use the back blade for.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2010 at 8:56pm
Hi Charlie,
Thanks for the info on the blade. Sounds like it might be good to make one some day. My bucket is about 6 foot wide I think. It has some points sticking out so I could not run it tripped.   I have a 3 pt blade on the back of my WD. It is older one but works good. I have a needle valve on the line to the rear tractor hydraulic cylinders, and a needle valve on the line to the loader hydraulic cylinders. I have to turn one off and the other on. It doesn't take too much time to do that. I also can lock both of them up if I want too, like for going down the road.
I need chains on the tractor too, or else I don't get much traction!.
Pastor Mike
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2010 at 8:59pm
My loader is a Farmhand F-19. Just had to put new rubber gaskets in it and metal gasket too.
Dennis(IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dennis(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2010 at 9:25pm
Not enough snow here yet.  I don't even have the rear blade on the 45.  But, I did mount the snowblower on the JD 322 garden tractor before I went in for heart surgery 4 wks ago tomorrow.  I did tell her that I think that I can run the JD w/snowblower,  WOW if looks could kill ;-)
It's OK, neighbor has a Bobcat that he will clean our drive with.
Dennis
