6 cylinder WD ad
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Topic: 6 cylinder WD ad
    Posted: 21 Dec 2010 at 9:00am
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2010 at 9:10am
 Too much paint, looks like a drive by shooting. I'd pass on that one just because  of the paint job.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2010 at 12:22pm
Yeah a bad paint job is just a PITA if you want to restore it...
ALLIS EXPRESS!
This year:
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2010 at 12:32pm
in desperate need of a sand blaster.
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2010 at 12:49pm
No, multiple coats of  spray oven cleaner and  power washing. If the application is any indication of the preparation, with a little help that paint would blow off, but it makes a mess and isn't my idea of a good time. Somebody local should look at it , their might be a rare  nos  AC  trinket in the toolbox to make it worth it .
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2010 at 1:11pm
Is that a 292 chevy?  I can't tell what kind of engine it is from the photos.  Also, does it look like the frame has been lengthened?  If did they just cram that engine into the 4cyl engine's spot?  Something just doesn't look quite right.
Hurst
1979 Allis Chalmers 7000
5800 Hours
Claus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2010 at 1:12pm
I'll bet they painted the tractor in one piece, sheet metal, wheels and all.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Claus Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2010 at 1:15pm
Also, I would have expected it to look like a 45 diesel, what did they do cut and add to the frame rails?  The steering box is still out front of the grille so something is wrong.
Sorry Hurst, I first missed your post.  You and I are thinking along the same lines.
Edited by Claus - 21 Dec 2010 at 1:16pm
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2010 at 2:20pm
Got the D hood and guage cluster.Probably didnt know the frame lenght was the same and spliced in.Not a Chevy,manifold wrong side.Manifold looks wrong for a 230-262 gas. If he thinks it's that valuable,he should keep it.
Karl in MD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Karl in MD Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2010 at 8:27am
I looks a lot like a Continental, possibly even from an early Oliver 70.  Maybe a "3 gear" from a Hart Parr 70.  Hard to tell under those 20 gallons of krylon road-hazard orange.
A man's got to know his limitations.
'51 WD, Roto-Baler,, A-C rake, '44 C, '42 B
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2010 at 9:38am
This tractor is only 30 miles from me. It is owned by a Junk yard so I am assuming it is not a real top notch job. I believe the frame was extended. he also has a WC for sale with really fresh paint on it.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2010 at 10:02am
continetol or hercules motor the way the manifold looks.
  Fenders are cut off and can anyone see the bat box?
 Bet the grease, rust and old paint is still under the slap and dab job.
Chris (swIA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris (swIA) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2010 at 10:05am
Paint, goofy engine conversion, bug eye headlights. even the wide front looks like it had a plate welded across the frame rails to hold it together. if there was every one not to save, this would be it.
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2010 at 7:17pm
Can't tell for certain from details other than the manifold and carb location, but it LOOKS like it might be a Hercules JXLD, or one of the slightly smaller ones.  If so, well, that's a heckuva horse... 331ci long-stroke six... a true industrial brute... but flathead, rather than valve-in-head, and quite a bit heavier than an AC engine.
GBACBFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2010 at 7:24pm
I've never seen a tractor painted with a paintball gun before.
are genuine." - Mark Twain
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2010 at 7:37pm
So, from the comments made , we could agree this is a RARE tractor ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2010 at 9:40pm
The manifold looks like the old 230 buda like the old A gleaner or co-op.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2010 at 9:14am
Rare, from the definition of being 'incomplete in finishing, or undercooked'...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2010 at 9:26am
Dave, I like your definition.
