What sprays.......
FredinInd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FredinInd Quote  Post ReplyReply Direct Link To This Post Topic: What sprays.......
    Posted: 20 Dec 2010 at 5:36pm
do you use to protect the wires, cap, plugs, switches on your tractors for winter work if they have to sit outside and you want them to start. I use WD40 and a silicon base spray. Is there any other spray you  use to keep moisture out from the rain and snow? Is this ok, or is there something better to use?   Fred
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2010 at 6:38pm
That is the one and only thing WD40 is good for. Don't use silicone if you think you might want to paint that tractor someday.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2010 at 6:42pm
Clear krylon is a good insulator and fairly weather proof, but not so hard on future paints as siliconE sprays. Silicon is a metal, doesn't spray nicely.
Gerald J.
