What's this reconditioned head for?
den/southern illinoi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Topic: What's this reconditioned head for?
    Posted: 19 Dec 2010 at 7:39am
Got some NOS parts from a closed dealer and some
reconditioned parts came with them.  I think this
head is for one of the lower numbered D series.  The
work on the head is well done but now I need to know
what it's for.  I'm thinking D 14 or 15.  The casting
number is 2917-12.  Thanks for any help.  Den
Own 4 wheel 20, 5020 and associated equipment and 1 electric forklift. Also a 720 garden tractor, 720 Diesel. 620 and soon a 616 garden tractor.
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2010 at 8:18am
Does it have a "AM- number" on top?
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2010 at 9:16am
Casting # sounds like a head for a C.
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2010 at 10:54am
Chris,
That was the AM casting # that I included in my first post, just forgot the AM.  So the casting # is AM 2917-12
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2010 at 11:12am
I have the head off a C on my bench right now and the casting is AM2917-8. a couple inches farther over is the date, 7 3 40, I would guess you have a C head from 1944.
GBACBFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2010 at 11:16am
Interesting info, Lonnie. Are you saying that if the #8 is 1940, #12 is four years later, or 1944? I need to be better versed in A-C's parts numbering, so any input will help.
are genuine." - Mark Twain
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2010 at 11:30am
On the blocks the suffix represents the date so I assume it's the same on the heads, you just have to know what year they represent and I know mine is a 1940 with -8 suffix. I could be wrong but it sounds right to me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2010 at 11:42am
Does the suffix on the blocks track the year, i.e. 40, or 0 for 1940, or an arbitrary number for a given year, and raised by one number for each subsequent year like this head example?
Sorry for hijacking your post, Den, but I waited until your question was answered. I'm trying to extract a learning nugget here.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2010 at 11:49am
Could the 8 represent the 8th design change in the head ?
Seems it would make more sense than if the same heads were cast in example 3  consecutive years wth no changes.
Don't know - just a thought.
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2010 at 11:51am
On the B/C/CA blocks the -10 is 1938, -11 is 1939 and so on. It appears that the heads use -8 as 1940, I don't have a second head to test the theory.
Edited by MNLonnie - 19 Dec 2010 at 12:24pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2010 at 11:54am
Larry, Brian Smith used a computer program to come up with the numbers. He entered known casting numbers with known year of production and came up with this set of numbers. http://people.clemson.edu/~wsmth/engcast.htm
The numbers seem to match pretty well with what other people have except for my 1951 CA669 has a "1956" block. I asked Dad about it and he said it was the original block. He bought the tractor new in 1951. Maybe I asked too late. Dad was 88 or 89 when I asked him about it and he never had trouble with long term memory.  Charlie
I was mistaken,the casting numbers were taken from a post on yesterdaystractors, the engine serial number and the tractor numbers were used to input into a computer program not the casting numbers.http://people.clemson.edu/~wsmth/SNFind/esn_tsn.htm
 My CA has an engine number that fits early in the range of the numbers listed for 1951 tractors. Therefore I have little faith in the casting numbers as determining the year of production.
Edited by CTuckerNWIL - 19 Dec 2010 at 12:05pm
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2010 at 12:06pm
  as long as i have been around since the fifties working in various foundries the am numbers are foundry numbers   not a-c #,s in my bookwhere these parts were made
   oliver-bremen fdry.   bourbon ind. fdry where oliver parts were made also  i also owned a frt. frt weight pattern once an had the am # on it also  fdry. identifaction
  an looking close some were changed every day for there refernces  my 2 cents
  worked at oliver fdry49-50-51  made castings for there plants mich.ill.ia.ind.
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2010 at 12:09pm
I really appreciate the info and the link. Thank you guys. That is good information, and helps me understand.
I do think Gary's thought for some parts has merit as well. I have three different cast B oil pans, and they all have different suffix numbers. These suffixes just don't seem to track to years.
If someone knew exactly what A-C was thinking on some of this stuff, they'd be the smartest person on the Forum!
Edited by GBACBFan - 19 Dec 2010 at 12:12pm
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2010 at 12:18pm
The dash number may have indicated the pattern serial number and its probable that several patterns were in use at the foundary at the same time for the same part. Then the oldest pattern would be scrapped when too worn and a new one made if production still justified having that many patterns in use.
Then the foundary may have not produced all parts the same month or year, but because making heads used different sand and iron mixes than making blocks, water pumps, manifolds, or transmission cases plus used different cores, copes and drags, they may have cast particular parts in spurts, possibly even spurts enough to last the factory for years at a time when the castings and the required techniques were particularly special.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2010 at 12:19pm
I could add some other info about my CA. It had engine work done twice between 1951 and 1969 or 70. Both times a rod bearing spun and the crank was polished or ground and bearings replaced. The guy that did the work on it is still around and I have questioned him about a possible block change. He said he doesn't believe the block was ever changed.
 I would like to know who Steve is that posted the info about the casting number to year relationship back in 2002.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2010 at 12:35pm
One thought on casting #'s that don't match serial #'s. A while back someone was posting about replacement trannys that came with no serial stamped, apparently you could restamp with your original serial # if you wanted but it wouldn't match the casting # in that case. Doesn't explain your CA #'s if it's all original. Just throwing it out there. Did you figure out what you have Den?
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2010 at 5:34pm
Thanks for all the info.  Lonnie.  it must be a head for a C.  Pretty interesting info included with the answer to my question so Larry, hijack any time...it helps me and I'm guessing others learn something new.
Just in case I don't get on here before, Merry Christmas and Happy New Year.   Den
MilesGray (CO/KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MilesGray (CO/KS) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2010 at 5:35pm
The head on my C shows AM 2917-8 and then date of 3-6-39...
Looks pretty good for a 71 year old head...
Miles Gray (CO/KS)
5 1938 B's, 1940 B, 1944 WF C, 1948 NF C, Gleaner A, White Top Rotobaler, 1957 IH Golden Jubilee... I'm either a collector, or crazy!
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2010 at 5:51pm
Interesting, kind of shoots my theory.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2010 at 9:17pm
Miles, What year is the C that 39 head came off of? When I worked at CAT, there were engine castings stacked in the yard for 2 years or more to "cure" so if they had a date stamp on em, that wouldn't necessarily have anything to do with the model year it was used in. I guess my opinion about the casting number goes along with pattern number or engineering change ideas and would have no direct correlation to the model year. That's not to say that a good portion of the engines produced in one year wouldn't have the same casting number.
This page was generated in 0.820 seconds.
