Easiest Way to Post Pic's from Photobucket
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Topic: Easiest Way to Post Pic's from Photobucket
    Posted: 18 Dec 2010 at 8:04pm
I have old AD scans I'm wanting to post here for viewing. I have re-sized them to fit, now what is the best/easiest way to upload them here as a new topic? Thanks for the help, puter's can be tricky.
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2010 at 9:12pm
If it is already in photobucket, just high light the IMG code under the desired picture, and paste it into the image icon on the new topic page.  I find I have to remove the 'IMG'  from the front and back of that paste, plus one set of http, as it automatically gives it an http.  Preview it, if it does not show the picture in preview, it will not show when you post it.
Greg Kroeker
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2010 at 7:08am
Thanks, Greg, going to try and post some old ad's,Chris/CT
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2010 at 8:01am
After posting to the open page you bring up, preview post , if not right just use clear form link and try again , your the only one who will know your attempt didn't work .
 You can also go back after and on posted reply and edit your post using that little gold gear and dropdown list under it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2010 at 8:10am
I'm having to "preview" twice to get the pic's to actually post, not sure why, maybe I will try Coke's suggestion to see if it will go 1st shot. I'm not sure how to post mutiples on 1 "New Post" request, have tried, but no luck usually.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2010 at 9:13am
Should be able to to put up multipal , if not just go back to gold gear and use edit , then add another picture to post.
This page was generated in 0.043 seconds.
