AC TL-10 Hub Removal
abrown6091 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote abrown6091 Quote  Post ReplyReply Direct Link To This Post Topic: AC TL-10 Hub Removal
    Posted: 17 Dec 2010 at 9:10pm
Howdy all, as you can see I'm attempting to remove the hubs from my Allis Chalmers TL-10 with little luck.  Does anyone have any other ideas other than this?  I am leaving it overnight with the jack putting around 2000# pressure on the puller but if that doesn't work then I am stumped.  The brake pads aren't stuck to the hub, its only stuck on the middle shaft and I doubt it has ever been removed before.  Unless there are any great ideas, I think I may have to heat the middle of the hub up with a rosebud and ruin the bearings and seal in there, but I sure hate to do that...
Thanks,
Allan Brown
Home-made puller for the TL-10 Hub
Dave A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave A Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2010 at 9:45pm
krol oil it over night and use a spreader bar on your jack and chain will give you more pulling power and pull straighter. Then use a air chisal on the thick part of your hub. The vibration will help  work the oil in and loosen the hub. You also could try a flat bar type puller that would jack off the center of the shaft. Tighten, then beat on the jacking bolt with a hammer
Edited by Dave A - 17 Dec 2010 at 9:49pm
Play the game for more than you can afford to lose... only then will you learn the game.
Winston Churchill
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2010 at 4:39pm
Make up a puller using 2 studs on each side to hold it to spread the force, use a center bolt against the axle end and crank as much force as you can , slight heat to center hub and then BFH on the bolt that contacts axle. About like removing a sprocket from crawler axle , lots of force and lots of words and some heat needed.
 Then on my D6 it was rent a puller from Cat as nothing else worked.
GBACBFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GBACBFan Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2010 at 8:13pm
A pic of a strongback similar to what Coke described.
are genuine." - Mark Twain
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2010 at 10:04pm
You got it , big fine thread bolt in the center and only thing missing is the BFH
