looking for a 816 steering hydrolic pump
Dave A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave A Quote  Post ReplyReply Direct Link To This Post Topic: looking for a 816 steering hydrolic pump
    Posted: 17 Dec 2010 at 7:40pm
looking for a pump for my 816 or a brand and model number. that would help me find parts
Edited by Dave A - 17 Dec 2010 at 7:44pm
Play the game for more than you can afford to lose... only then will you learn the game.
Winston Churchill
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2010 at 2:40pm
that one should have the numbers stamped in the body
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2010 at 3:07pm
Believe Cesna made most of those pumps, and is that all that pump is is steering ?
I had one pump on New Holland Skidsteer that NH wanted $1200 for , found a new Cesna that sold for $300 but I had to use my input shaft from old pump as the part was exclusive to NH and the pump with the right shaft was NH ONLY order.
 See ifthere is a hydraulic shop in your area to check it out if you cant find parts or fix yourself.
 My 715 uses a Char-Lyn orbital steering gear
Edited by Coke-in-MN - 18 Dec 2010 at 3:09pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave A Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2010 at 3:29pm
think it is a Webster 6 gpm @1500psi if I had the Webster model  and manufactur part number. Life would be good.  The numbers are a AC part number have a crack in the gear plate. The gear plate is still advailable for $138 +seals. Have a shop looking for a new pump.
Edited by Dave A - 18 Dec 2010 at 3:56pm
Winston Churchill
ac-mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac-mike Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2010 at 7:39am
If you find a new one I would be interested in any information or maybe your old pump for parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave A Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2010 at 5:22am
will do. might give you a deal on the whole tractor
Winston Churchill
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac-mike Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2010 at 10:36am
If interested, i used a pump off a massey ferguson and adapted the tank to work. It is working for me  but with just a little seep. Hard to hold the tank with the heavy pickup line.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave A Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2010 at 3:30pm
Winston Churchill
