my new log splitter
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Topic: my new log splitter
    Posted: 16 Dec 2010 at 9:05pm
hey all,
i just wanted to share my new log splitter.  just finished it last weekend.  this was sunday morning at 15 degrees.  i was warm in the cab.  the log was red oak 24" at the small end and 30" on the big end.
thanks for watching.
Derek Wekenborg in Mo
http://www.youtube.com/watch?v=C_Ehu_H62Zw
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2010 at 11:10pm
Nice work!
Edited by 427435 - 16 Dec 2010 at 11:12pm
Mark
GTH-L Simplicity
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2010 at 1:50am
I have been thinking about building the same thing. Except  I want to make it flip over  also so you can still do some smaller pices by hand If need be.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2010 at 8:37am
Does your rig lift up high enuf so you can drop the split pieces into
the back of a small dump truck; looks so.
Boy, what a back saver!  That red oak in that size is some heavy
stuff to move around by hand!
Nice job!
FredinInd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FredinInd Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2010 at 9:24am
   I like that set-up big time!
Wes (VA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes (VA) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2010 at 9:34am
Awesome!  And its mounted on a good machine might I add..!  Me and dad have been wanting to build something like this for a while to use with our S250.  -Wes
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2010 at 4:55pm
thanks.  Dad and i burn about 14 - 16 cord of wood a year and i had been doing most of the work.  it does lift high enough to drop the pieces in a dump trailer.  this was just the trial run on some really big stuff and my buddy took a video.  we had talked about making it flip over but we have another splitter that we will use for the smaller stuff that mounts on the 3 point.  i also made the wedge removable so that i can change from a 4 way to a straight blade and I'm planning on making an 8 way.
I will tell you that we built our own I beam.  A regular W flange beam will twist on an uneven load like you get splitting wood and when the wood splits it will send pieces flying.  So we made the web out of 2x6 rectangle 1/4" wall to resist twisting and the flanges are 4" x 3/4" plate and i wish i had used 3"x8" and 3/4"x5".  4" cylinder had around 39,000# of force at 3000 PSI.  i could see it flex when i tried to shear a 8" hickory limb.  i probably won't try that again.
Dave A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave A Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2010 at 5:48pm
that would be a really neat set up. If it was on a loader back hoe. Put it on the back hoe and sit in a heated cab. While you put it over the truck and split it
Edited by Dave A - 17 Dec 2010 at 5:52pm
Play the game for more than you can afford to lose... only then will you learn the game.
Winston Churchill
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2010 at 5:54pm
I thought about that Dave but i didn't have a backhoe.  Seemed like a large investment just to split wood.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave A Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2010 at 6:31pm
Looks like a great idea. Cutting wood isn't cheap. What a few guys are doing here are doing. Is buying a semi load in pulp lengthes. Spliting it an selling half to pay for the other half.
Winston Churchill
This page was generated in 0.162 seconds.
