Dr Allis - 301 front plate question?
Eric[IL] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric[IL] Quote  Post ReplyReply Direct Link To This Post Topic: Dr Allis - 301 front plate question?
    Posted: 16 Dec 2010 at 8:01am
Is there any reason why a front plate from a 649T or 649I 301 diesel engine should not fit onto a 433T or 433I 200 diesel engine?  I want to attach a hydraulic pump to the front of my 200 diesel engine for a AC 706B forklift application.  Thanks
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 16 Dec 2010 at 8:58am
any of the front plates will fit.  Both are same block front and rear , just one is 4 cyl and other is 6 cyl.  It is not a 649T or I you need as these were available in many different styles. It is one off a 6060-6070-6080 AC that you need.  Keep
in mind there are 2 hydraulic pump drive housings as well.  So, match the fuel pump mount and the pump drive area as well.   Fuel Pump possibilities were DM, DB Roosa's and Simms.
