Heavy duty front rims for FEL?
paulinkansas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote paulinkansas Quote  Post ReplyReply Direct Link To This Post Topic: Heavy duty front rims for FEL?
    Posted: 15 Dec 2010 at 11:10am
My D17 has 2 different kinds of front rims.  One seems to be a a heavy duty kind, the other one seems thinner and has broken.  I bought a replacement rim, but it also broke after about 12 hours of moving topsoil with the FEL.
Does anyone know where to get the heavy duty (16 x 4.25 5-hole) front rims for a D17?
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2010 at 11:21am
I had this trouble several years ago moving big bales with my D15 II. most of the bigger, wider, heavier rims would not fit due to the offset. Wouldn't fit because the tire would hit the vertical axle spindle shaft. I ended up cutting my wheel centers out and welding to some heavier wheels. I could space the offset properly before I welded them to fit. 9.5lx16 tires cleared the uprights about 1 1/2 inches. Gave me a lot more strength and flotation.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2010 at 11:46am
valubilt has a 15 x 6 2300 pound 5 bolt rim. http://www.valu-bilt.com/product_info.php?product_id=8643&item_number=A%201231943
Shoup has some rated at 1200 and 1800 pounds.
Last time I wanted special rims, one place I found them was a rim store in Des Moines where they had various widths, strengths, and offsets. You do need to be sure of the offset.
Gerald J.
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2010 at 1:37pm
I believe Tony's tractor parts has them.
He is a sponser on this site, should be able to find him in the parts page.
Front rims
Edited by Matt MN - 15 Dec 2010 at 1:39pm
