8050
wheatbreeder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wheatbreeder Quote  Post ReplyReply Direct Link To This Post Topic: 8050
    Posted: 15 Dec 2010 at 10:14am
what would make my battery and engine oil light stay the battery light usually goes out after 1200 rpm
thanks
Morley
Farm stuff 8050,6690,175,F2,5050,WD
michaelwis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote michaelwis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2010 at 10:19am
MY 7040 DID the same thing .. i just quit lookin at the light and got over it .. touchy sensor ?
WD WD45 DIESEL D 14 D-15 SERIES 2 190XT TERRA TIGER ac allcrop 60   GLEANER F 6060 7040.and attachments for all Proud to be an active farmer
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2010 at 11:33am
sender unit on the oil pressure most likely. Pull the wire off the sender and ground it to engine block and see if light goes out.
Wink
I am a Russian Bot
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2010 at 11:46am
Just to be safe, I would put a gauge on the block and check to see how much PSI I did have. I like to sleep at night.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wheatbreeder Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2010 at 3:01pm
Electricity is a funny thing I sensor wire was not contected shame on me the lights still came on after 5 minutes of running the went out bad grounds or ghosts
thanks for the help
Morley
This page was generated in 0.043 seconds.
