Glow plug, manifold heater amps?
E7018 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote E7018 Quote  Post ReplyReply Direct Link To This Post Topic: Glow plug, manifold heater amps?
    Posted: 14 Dec 2010 at 6:27pm
On a 301 engine, how many amps or watts is a glow plug intake manifold heater? I need a starter solenoid switch, right? Not a 40 amp automotive relay?  The inch square ones.
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2010 at 12:31am
All the manifold heaters were operated by a solinoid switch.It looks like a starter solinoid for a old Ford but I don't know if it's just that.Don't know the amps but it uses cables not wires.
Edited by Steve M C/IL - 15 Dec 2010 at 9:55am
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2010 at 5:57am
I was able to find a solenoid at a dealer for my 185 when it needed one.   I used a solenoid from a garden tractor for a forklift (same heater) when it needed one, worked good.  Ford's a good bet, look for single pull in terminal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2010 at 6:44am
My A-C diesel forklift has a Ford starter solenoid supplying the power.You can buy high current(60Amp) push button switches that should work but cost more $$ !
I've thought about having a second battery just for the glowplug...another winter project !
Roddo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roddo Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2010 at 9:41am
The Ford starter solenoid sounds like a good idea.  The 7.3 diesel used basically the same solenoid for it glow plug controller.
Bruce Nelson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bruce Nelson Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2010 at 9:56am
I just tested the heater on my 180 and found that it draws 51 amps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2010 at 12:10pm
The glow plug relay on a 7.3L Ford looks similar, but they are not the same as the old fender mounted starter relay. The difference is they don't ground through the bracket, and if you buy them from Ford they're over $100.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roddo Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2010 at 1:51pm
I never said use a glow plug relay from Ford.  I said the fender solenoid would work as it is BASICALLY the same. Never claimed them identical.
As soon as I hit post I knew you'd chime in.
Edited by Roddo - 15 Dec 2010 at 1:51pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 15 Dec 2010 at 1:55pm
Same 'Ford ungrounded' relay is only $9.98 at the local Princess Auto, less than 10% of the Ford dealer's price !
