8000 series FWA tire sizes
AdamA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AdamA Quote  Post ReplyReply Direct Link To This Post Topic: 8000 series FWA tire sizes
    Posted: 13 Dec 2010 at 10:56pm
I have seen pictures of 8030's/8050's with what looks like a shorter/wider tire on the front than my 8030's 14.9x28 I would like too level my tractor and also gain clearane for the loader,can anybody tell me where I can find rims and what size they might be?
57'D-17,78'185,83'6080,76'7040,84'8030 FWA.02'Dodge cummins
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2010 at 11:05pm
The sales lit shows 2 different sizes depending on your rear size. 18.4-38 had 13.6-28s, and 20.8-38s or 18.4-42s had 14.9-28s.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AdamA Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2010 at 11:09pm
Bought mine with 18.4x38 on the back and 14.9x28 on the front so it sits "uphill" and dosen't have much clearance for the loader know I have seen some with what looked like a 18.4x24? wondered if anybody had one?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2010 at 11:13pm
Im just going by what it said in the brochure. If you could find rims you might get by with 16.9 or 18.4-26s??? I know you cant change the ratio much at all.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AdamA Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2010 at 11:15pm
Found an 8070 on ironsearh w/18.4x26 wonder what the circumferance is compared too my 14.9x28....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2010 at 11:26pm
The lit I have doesnt even list the option of fwa for the 8070. It must be an early one theres no date on it. I have seen an 8070 with the 18.4-26s. Im not sure if the gearing in the front end would have been changed for that model.
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2010 at 12:08am
I've got 16.9 x 26 on an 1984 model 8050. It seems that the later models had wider tires on front.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2010 at 6:44am
Service school made it clear that the front and rear tires had to be certain sizes otherwise you'd prematurely wear out not only your tires but also the driveline. I'd check with the dealer as to correct sizes.
Wink
I am a Russian Bot
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2010 at 11:12am
The FWA option for the 8070 was a slightly later release than the other 8000's.
What we found during testing was that a front tire size that gave a slight over-speed of around 1.5-3.0% (if my memory is correct) gave the best results in the field.  Less gave issues turning and more could lead to hopping in higher but normal slippage conditions.
Try and stay close to the factory sizes.
Mark
GTH-L Simplicity
Russ-neia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Russ-neia Quote  Post ReplyReply Direct Link To This Post Posted: 14 Dec 2010 at 11:57am
The 8000's always look like they are driving up hill.  If you put a small enough tire on to "level" it, the tire will be too small and cause gear lash problems.  The 18.4x26 was a later option to go with 20.8x38 or 18.4x42 tires.  There was also a 13.6x24 option to go with 18.4x34 tires, but I have never seen an 8000 with 34" rears.
