CA hydraulic cylinder on B?
yochujr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote yochujr Quote  Post ReplyReply Direct Link To This Post Topic: CA hydraulic cylinder on B?
    Posted: 13 Dec 2010 at 8:43pm
I am in the process now of getting rid of the old cylinder that somebody rigged up and I was really considering going to a single B cylinder.  Some people have brought to my attention that a single B cylinder may not have quite enough to lift heavier implements on my 3-point.  I guess my other two options are to possibly go with 2 B cylinders which would require me to fab up two new brackets on the rocker shaft to attach to or just go with a single CA cylinder.  Does any one have any insight as to what it would take to make a CA cylinder fit on a B tractor?  Thanks in advance for any input.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2010 at 9:11pm
I think somebody recently posted a picture of a CA cylinder on a B. It might have been a Snap Couple B.?????
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2010 at 9:28pm
A single cylinder on My C will lift enough to lift the front wheels. if your implement is heavery than that you might need a bigger tractor.
Brad MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad MI Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2010 at 9:54pm
My Snap Coupler B has a CA cylinder on it. If AC thought it needed a CA cylinder I guess I'd assume a CA cylinder would work well for a 3pt conversion as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote yochujr Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2010 at 10:23pm
Would you happen to have any pictures you could share?  The 3-point is homemade but it still attached to the pin on the frame and the arms on the rocker shaft the same as original (I believe).  I was hoping to find out if a CA cylinder would mount up to my setup without any modifications.  If not, how much work I'm looking at.
Post Options Post Options   Thanks (0) Thanks(0)   Quote yochujr Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2010 at 10:25pm
Interesting.  I've heard some say it will not lift anything more than a light duty blade very well and other said they have an enormous amount of lift capability for being so small.
Post Options Post Options   Thanks (0) Thanks(0)   Quote yochujr Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2010 at 10:47pm
Yeah, that was on one of my previous threads.  I was having a lot of hydraulic issues when I first bought the tractor but I think I'm slowly getting it straightened out.  When I first got it, I was having problems with the pump and an aftermarket cylinder that was rigged up to fit that was also leaking very badly.  I found a used pump that looks to be in good condition and now I'm trying to replace the cylinder that is a little closer to the original and that will do what I need it to do.
