Wide front toe?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Topic: Wide front toe?
    Posted: 13 Dec 2010 at 5:46pm
Well, got the other part fixed for the wide front and got it on today.   All I have left to do is install the tires/wheels, tie rods, and adjust them and unblock it and then I can go put my loader on.   As far as setting the toe in/toe out on a tractor's wide front, what do you guys usually set it up as?   I used to do it on the race car's with the tires about an 1/8" toed out.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2010 at 7:07pm
Rear wheel drive you want toe in, how much depends on the slop in the spindles, the steering arms and the tie rod ends. 1/8 to 1/4 is typical for a farm tractor. Closer to 1/4 than 1/8
Gerald J.
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2010 at 8:27pm
I would say 1/8-1/4 inch toe in.
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2010 at 8:59pm
most of the manuals call for 1/8-1/4
This page was generated in 0.107 seconds.
