Looking for Set Screws & Jam Nuts
Jeff(WD45-SATX-TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WD45-SATX-TN) Quote  Post ReplyReply Direct Link To This Post Topic: Looking for Set Screws & Jam Nuts
    Posted: 12 Dec 2010 at 8:38pm
Does anyone have any surplus set screws and jam nuts for sale? Or recommend a source for new. I need a couple for the brake pedals and one of the small ones for the foot clutch pedal adjustment.
Thanks in advance
Jeff
Edited by Jeff(WD45-SATX-TN) - 12 Dec 2010 at 8:39pm
1954 WD45 NF "Iron Tater"
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 8:54pm
The little one can probably be had from places like McMaster-Carr www.mcmaster.com providing a cup point works. The big one still has a valid AC number and dealers witih AC parts have them, something like $31 each last I checked by part number. And that dealer at Marshaltown actually had one in stock.
Gerald J.
LannyMTN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LannyMTN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 9:08pm
Jeff,
You have mail.
Lanny
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 10:18pm
Richard Aiken prolly has all kinds of em.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2010 at 8:15am
The pointed ones for the starter (the same?) come up on e-pay regularly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2010 at 8:29am
$31 dollars, holly setscrew batman, I'm glad I have a usable lathe out in the shed. I could turn that taper in a couple minutes.
R Aiken View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote R Aiken Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2010 at 8:41am
Yes but everything is under snow and it is cold out. I am staying in the house and burn firewood.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2010 at 10:36am
My post back in August said:
I saw a few of those at Marshalltown at the Mid-Iowa Antique Power Association Show. Most had hex heads, looked like about 11/16", maybe 5/8" with thin but large lock nuts. A couple had screwdriver slots, as if they were conventional set screws used as replacements. I didn't get to see the taper.
I visited the Central Iowa Farm Store at Marshalltown after lunch and asked about those set screws. They have ONE in stock part number 207872 for $39.48. I should have asked, "Is that for a box of ten or 25?" I wished I had a dial caliper with me to measure that sample.
To which Ray posted:
$10.00 each. 785-353-2392
So if they can be had for that price I can't buy one for measuring the taper and go turn them in my little lathe.
Gerald J.
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2010 at 10:43am
The ones with the screwdriver slots were originally used to locate and retain the starter.
Jim Blue View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Blue Quote  Post ReplyReply Direct Link To This Post Posted: 13 Dec 2010 at 11:15am
Try Sandy Lake Iplement.  I bought the set screw in your photo from them last spring.
