Priming/painting question?
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Topic: Priming/painting question?
    Posted: 12 Dec 2010 at 3:03pm
What do you guys use for primer on small Parts? When I get time I sand blast and clean parts then prime them. Most primers say to paint within so many hrs. or days.  Sometimes these parts will set on a shelf for months. Do they need reprimed or reblasted and primed or what? Just curious as to what others do.
jb from md View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jb from md Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 4:55pm
i use an epoxy primer, then just scuff before painting. been doing it for years with no problems. ...Jb
8050 FWA, 190XT, 185, Styled wc, Unstyled wc, (2)C, (2)WD45NF, WD45WF, WD,416h, 716h, 312h, 8070 pedal.
firebrick43 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote firebrick43 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2010 at 7:03pm
Epoxy is one of the few primers that is not porous.  Others will allow air/moisture to penitrate and cause rust.  As JB said, you need to scuff any primer that has set for some time before painting.
